I own scanners, too. The Uniden BC-125AT is about the only portable scanner that I've owned or used that has halfway decent sensitivity and selectivity. What I don't like about it is its battery setup. Yes, it will use AA alkaline or rechargeable batteries, but constantly changing out batteries will wear out the battery receptacles long before the radio wears out. Also, I admonish anyone to NEVER charge the rechargeable batteries in the BC-125AT radio with the USB cord. The charging circuit is prone to malfunction and can overheat and destroy the radio, if not potentially starting a fire. I caught mine just in time--it had started to melt the case and would have destroyed the radio had it been on the charger for just a little while longer. As to the Uniden "high-end" digital scanners like the SDS-100 (which I own), my experience has been that their performance in the analog VHF and UHF bands just plain sucks.
As to the post above, the federal allocations of the 162-174 mHz is 12.5 kHz channel spacing, WITH 2.5 KhZ frequency step spacing in the commercial, industrial, and public service uses. The whole purpose of narrow-band "re-farming" was to double the amount of available channels in a given frequency spectrum--VHF in this case. Now, amateur radio may still operate in wide band, and most do--this is because there was so much "legacy" amateur equipment out there that was not narrow-band capable. Also, a lot older wide-band-only commercial radio equipment obsoleted for use in those bands was surplus sold into the used amateur radio market. The whole point of my original post, however, was that amateur radios often serve a dual purpose for the user--communicating on amateur channels and monitoring the commercial and public service channels. Those non-amateur "splinter" 2.5 kHz-spaced channels are coming into more use. The typical amateur radio (the "hybrid" Chinese radios being the major exception) can not tune those splinter channels because of the 5 kHz tuning step used in those amateur radios.
My final editorial comment. If people wonder why amateur radio is decreasing in popularity, it is, in part, because a lot of amateur radio operators just get hide-bound stubborn about accepting any new technology other than what has been around for decades. I can understand some of that--I'm not keen on jumping on every new hardware or software gizmo "just because"--but I don't see why a 2.5 kHz tuning step feature in an amateur radio should be such a "not on my amateur radio" thing.
