My ws1080 has the latest firmware 4.8 is there any way to roll it back to an older firmware?
minasha
NYC
My ws 1080 has the latest firmware 4.8. is there a way to roll it back to previous firmware?
minasha
NYC
My friend changed the firmware back to 3.8 and all the problems are gone!
I don't know why 4.8 caused problems but as long as it works now I'm happy
Reconrider
EST
Explain how it was done so others can use it if they have issues.
minasha
NYC
Originally I updated to 4.8 using the EZ scan software.
My friend rolled it back to 3.8 using software he had on an SD card that he had.
I don't know what it's called or where it came from.
tvengr
Well Known Member
Baltimore County, MD
Just checking that you have an actual WS1080 and not a PSR-800, Pro-18, or Pro-668 updated to a 1080 by the Whistler Legacy Upgrade.
minasha
NYC
I did use the EZ scan to do the update to 4.8 but it doesn't give you the ability to roll back if you want to.
I had nothing but trouble with 4.8 such as:
1- when doing a limit search it would not decode DMR or P25 channels only conventional.
2- When going to a scanlist of mine I lock on wildcard and no TG's come in
Now back to firmware 3.8 everything works normal again I will not look to update firmware anymore only DSP.
I don't see any advantage in 4.8 anyway.
minasha
NYC
I will see how the scanner does over the next couple of weeks and look into contacting the tech support if needed.
Thank You
