Myrtle beach, pro-97 trunking programming help needed.
wmbio
Cumberland, Md
Hi all,
I am new to the group, I am looking for someone who owns a new Pro-97 to help me program NMB, MB and the palmetto 800 trunks for Horry county into the radio.
I have no motorola trunking systems in my home area to even practice setting up talk groups or control channels. I am not currently in MB but travel there extensivly during the year and would like to take my new radio with me.
As you might say, I need spoon fed this information, if someone is willing to help.
Please e-mail: wmbio@hotmail.com
Thanks,
Huffy
Grog
Banned
West of Charlotte NC
Have you downloaded win97 to program it? It's makes it a lot easier.
I'm working on a 93 file, but I'm not sure if there is a way to change it to the 97 format.
I'll check in tonight from work to update.
DaveIN
Founders Curmudgen
West Michigan
For the Motorola analog trunked systems, all you will need are the control channels programmed into memory
(there are usually 4 of them), the 97 will find the voice frequencies for you and display the talkgroups (without alpha tags unless you program them). Just be sure you have the frequency and Trunked id (F + the Trunk button) set to MO for Motorola.
Use the information from the Radioreference database when programming the 97 by hand or with win97.
Keep in mind you can try Win97 for 30 days, but you will need to get the 20-289 or black bag cable to use the software to upload to the PRO-97.
http://radioreference.com/modules.php?name=RR&ctid=2338
http://starrsoft.com/software/win97/default.asp
Also if yo are a donating member to Radioreference, you can import the frequency and trunked information directly into Win97.
wmbio
Cumberland, Md
Sorry, I do not have any software or patch cables to work with. As I said I do not have any Motorola trunking in my area to test with. I am trying to understand so be patient with me please.
Are you saying all I need to do is identify the trunk control channels, program only the control channels and set them for MO, and they will do the rest?
I do not need to program each active trunk channel in the group?
Wmbio
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
Actually, you don't need to know which of the licensed frequencies are control channels.
As long as you are in the vicinity of the target trunked system, you can simply enter all the licensed frequencies, and the scanner will search for the control frequency in use.
Without entering any talkgroups, you can "search" the system to listen and identify talkgroups.
With regards to Motorola 800 MHz trunked systems close to you (Cumberland / Allegany Co., Md), have you check the Airinc system near the airport in Wiley Ford, and the Allegany County system in Midland ?
Jeff Multer
Fort Mill, S.C.
wmbio
Cumberland, Md
Jeff,
The trunks you mention are LTR ( Johnson ) and I have these sucessfully installed in my Pro-97, our local sheriff and fire depts use these. Not sure what the airinc system is? Do you have the freqs? I will listen.
OK, for the pro-97 trunking in Myrtle beach, install all known freq. in the trunk group, set to MO, lock out the user ID's I do not wish to listen too for Horry county. Am I on the right track?
Does each trunk need to be in a seperate bank?, like I have to do with the LTR systems?
Wmbio
jeffmulter
That should have read "Aeronautical Radio, " which is a company that handles the tracking of aircraft, cargo and personnel through software and radio networks spanning the globe.
They have used five-channel 800-MHz Motorola Type I trunked systems at many airports, in support of local operations. Some of those systems have been replaced with Nextel equipment setup specifically for the use of the airport personnel.
The airport at Wiley Ford is licensed for trunking on 858.7875, 858.8125, 858.8875, 859.7875 and 859.8875. The current license covers use of both analog and digital (Nextel) transmissions. Your best bet is to listen to the frequencies for a typical Motorola control channel.
Yes ... I don't know if the Pro 97 will trunktrack multiple control frequencies in the same bank, but the talkgroup I-Ds will be different for each system ... so use a separate bank for each.
You can also enter in conventional channels with the trunked systems. For instance, include Myrtle Beach's conventional fire frequencies in the same bank as their trunked system. And the police conventional tac channel.
> OK, for the pro-97 trunking in Myrtle beach, install all known freq. in the trunk group, set to MO, ...
Set both the bank and the individual trunked frequencies to Motorola trunking.
>> ... lock out the user ID's I do not wish to listen too for Horry county. Am I on the right track?
Yes. I would go ahead and enter the talkgroups that interest you in the scan lists. In "open" mode, any of those talkgroups will display with the alpha you entered, so you'll be able to tell if you're hearing a talkgroup already identified on Radio Reference (or whatever source you use).
Having the key talkgroups entered beforehand will also enable you to concentrate on them if something significant occurs while you're monitoring.
Jeff Multer
wmbio
Cumberland, Md
Jeff,
Nextel is everywhere! Noisey as H*** all over the 800 band.
Let me take a listen to the airport freq's.
I have done as you suggested, each bank in the 97 holds the trunk freq's and talk groups, I have 5 banks programmed tonight.
I do have mutiple control channels in the Horry trunk, may have to seperate these into individule banks with the same talk groups but will wait till I get to MB before I do that, I do not know if the 97 can handle several control channels in the same bank....Anyone????
NMB trunk and talk groups
The Huge Horry trunk, 15-20 freq, and talk groups
The new MB public safety trunk and talk groups ( Fire & PD came off the Horry trunk per notes here at RR )
Surfside trunk and talk groups
Palmetto 800, Conway and NMB with talk groups
"You can also enter in conventional channels with the trunked systems. For instance, include Myrtle Beach's conventional fire frequencies in the same bank as their trunked system. And the police conventional tac channel."
Conventional fire & Police tac channels? Can you Identify for me, not seeing these in the look up lists. Where would you add these if you were programming?
So far so good on this end, thank you for your time!
wmbio
jeffmulter
>> I do have mutiple control channels in the Horry trunk, may have to seperate these into individule banks with the same talk groups but will wait till I get to MB before I do that ...
Multiple control channels that are part of the same site / system are "fine." The site controller may rotate between them, so only one of the control channels will actually be in use at any moment in time.
Assuming the Pro 97 can track more than one "active" control channel in the same bank, the problem occurs when the active control channels represent two different systems. Talkgroup xxxxx may have one use on system 1, and another use on system 2 ... but you can only program one scan list per bank.
If the Pro 97 cannot track more than one active control channel per bank, then it will lock onto the first active control channel it finds, and ignore the others until it loses that control channel signal.
Look at the frequencies here:
The fire departments and EMS still maintain a simulcast of dispatch on VHF, for paging purposes. Some of the other frequencies may be active for interoperability with neighboring agencies. A couple of the fire VHF assignments are relatively new ... not left over from the pre-trunking days.
Jeff Multer
wmbio
Cumberland, Md
Jeff,
Not a paid member of this site yet, so your link doesn't work for me, can you C&P the freq. info please.
The large Horry county trunk freq's and control channels are listed here at RR as being in the same trunk group from my reading, just a very large group with several different control channels.
So far no traffic or control channels found on the airport freqs, I will continue to monitor.
thanks
wmbio
jeffmulter
I'll paste to the end of this message, but you don't have to be a paid RR member to assess the database ... you just need to be a registered member.
From the rr home page ... www.radioreference.com ... click on the RR database link at the top of the page, then choose the state, then choose the county.
It's likely not operational, then. If it was a Motorola trunked site, and within range, the control channel would be making its familiar "rat-tat-tat" 24 / 7.
Jeff
(keep in mind the RR database might not conform very well here due to size / width restrictions)
Fire/EMS
County Fire and EMS commincations are carried on the Horry Co. TRS
Frequency Input License Type Tone CH Description Mode
154.40000 154.01000 WPML296 RM 167.9 1 Horry Co. FD Dispatch
153.74000 WPPU836 M Horry Co. FD FM
154.84500 WPPU836 M Horry Co. FD FM
155.43000 WPPU836 M Horry Co. FD FM
155.80500 WPPU836 M Horry Co. FD FM
155.29500 KZE707 BM 167.9 2 Horry Co. EMS Dispatch FM
155.40000 KZE707 BM 167.9 3 Horry Co. EMS Talk around FM
451.82500 KZE707 F 1 Horry Co. EMS FM
155.34000 KZE707 BM 167.9 Horry Co. Hospital FM
155.23500 KNAY819 BM 167.9 Horry Co. Rescue FM
Police
Horry Co. police communications are carried on the Horry Co. TRS.
Frequency License Type Tone Description Mode
154.80000 KNDF962 BM Horry Co. PD FM
154.86000 KNDF962 BM Horry Co. PD FM
155.01000 KJG707 BM 167.9 Horry Co. PD Regional Police FM
155.68500 KNDF962 MF Horry Co. PD FM
Myrtle Beach, City Of
Fire
Myrtle Beach FD communications are carried on the Myrtle Beach TRS.
Frequency License Type Tone CH Description Mode
154.22000 KNIE485 RM 167.9 1 Myrtle Beach FD Dispatch FM
153.83000 KNIE485 MF 2 Myrtle Beach FD Repeater Input FM
154.17500 KNIE485 BM 167.9 3 Myrtle Beach FD FM
Police
Myrtle Beach PD communications are carried on the Myrtle Beach TRS.
155.01000 KJG707 BM Myrtle Beach Regional Police FM
868.63750 156.7 3 Myrtle Beach PD SC TAC 4 FM
Conway, City Of
Fire
155.88000 KDN489 RM 167.9 1 Conway FD Dispatch FM
153.80000 KDN489 MF ? Conway FD FM
153.93500 WPLV377 M ? Conway FD FM
154.35500 KD26764 M 2 Conway FD FM
Surfside Beach, Town Of
Fire/Police
Surfside Beach FD and PD communications are carried on the Myrtle Beach Communications SMR TRS located in Surfside Beach.
Frequency Input License Type Tone Description Mode
155.53500 154.80000 KNEK682 R 167.9 Surfside Beach FD Dispatch
155.01000 KNEK682 167.9 Surfside Beach FD Fireground FM
154.99500 WPLD284 BM 167.9 Surfside Beach FD FM
155.26500 WNGA874 BM Surfside Beach Rescue FM
Other Services
Frequency License Tone Description Mode
155.92500 WQAG324 167.9/CSQ Surfside Beach Public Works FM
Grog
Banned
What I would program 1st, is.........
154.400
155.295
155.400
154.220
at a mimuim. Depending on where you will be. I don't monitor Conway or Surfside as I don't go there whem I'm around.
154.400 County Fire Dispatch. Some traffic will be on the 800 TG, but this will let you know who is going ehere. If you're near the north end of Horry Co, you may get Brunswick Co. bleeding over from 154.415.
155.295 When I left in 99, they were using VHF mobiles and mostly 800 HTs. for EMS work.
155.400 With 800 TGs I'm not sure how much they will use this as a EMS TA ch. From another post (and the Horry Co website) It is a combined Fire/EMS dEpt now.
154.220. If you're in MB, this is handy. BTW, the input (153.830) is (was) the same input for Brunswick Counties 154.415 repeater. As a Firefighter in the sounth end of Brunswick Co, I'd monitor the repeater input as well so I could hear the local units when we could not make the repeater.
