SCTAC and freq's
REGIONAL MUTUAL AID TALKGROUPS
NAME DEC ID HEX ID HP TROOP
CALLING CHANNEL SCCALL 801947 79B Statewide
REGION 1 COMMON REG01 801955 7A3 Troop #1
(“Region 1 Counties”) Richland, Lexington, Kershaw, Lee, Sumter, Clarendon
REGION 2 COMMON REG02 801959 7A7 Troop #2
(“Region 2 Counties”) Abbeville, Laurens, Greenwood, Newberry, Saluda, Edgefield , McCormick
REGION 3 COMMON REG03 801963 7AB Troop #3
(“Region 3 Counties”) Spartanburg, Greenville, Anderson, Pickens, Oconee
REGION 4 COMMON REG04 801967 7AF Troop #2
(“Region 4 Counties”) York, Cherokee, Union, Chester, Lancaster, Fairfield, Chesterfield
REGION 5 COMMON REG05 801971 7B3 Troop #5
(“Region 5 Counties”) Marlboro, Darlington, Florence, Dillon, Marion, Horry, Georgetown, Williamsburg
REGION 6 COMMON REG06 801975 7B7 Troop #6
(“Region 6 Counties”) Colleton, Jasper, Beaufort Berkeley, Dorchester, Charleston
REGION 7 COMMON REG07 801983 7BF Troop #7
(“Region 7 Counties”) Aiken, Barnwell, Allendale, Hampton, Bamberg, Orangeburg, Calhoun
REGION 8 COMMON REG08 801987 7C3 Assignable
(“Region 8") Assignable for special events/emergencies (Coordinate with EMD/CIO/Motorola).
REGION 9 COMMON REG09 803263 CBF Assignable
(“Region 9”) Assignable for special events/emergencies (Coordinate with EMD/CIO/Motorola).
REGION 10 COMMON
REG10 803267 CC3 Assignable
(“Region 10”) Assignable for special events/emergencies (Coordinate with EMD/CIO/Motorola).
Sites for Regional talkgroups are set up to conform to the South Carolina Highway Patrol Troops.
STATEWIDE MUTUAL TALKGROUPS
NAME DEC ID HEX ID
SC CALLING CHANNEL SCCALL 801947 79B
STATEWIDE MUTUAL AID CH 1 SCMA01 801341 53D
STATEWIDE MUTUAL AID CH 2 SCMA02 801349 545
STATEWIDE MUTUAL AID CH 3 SCMA03 801821 71D
STATEWIDE MUTUAL AID CH 4 SCMA04 801829 725
STATEWIDE MUTUAL AID CH 5 SCMA05 801837 72D
STATEWIDE MUTUAL AID CH 6 SCMA06 801845 735
STATEWIDE MUTUAL AID CH 7 SCMA07 801853 73D
STATEWIDE MUTUAL AID CH 8 SCMA08 801861 745
STATEWIDE MUTUAL AID CH 9 SCMA09 801869 74D
STATEWIDE MUTUAL AID CH 10 SCMA10 801877 755
S C AIR TO GROUND SCAIR-GRD 800241 0F1
SC Calling Channel is monitored by SC Emergency Preparedness.
LAW ENFORCEMENT MUTUAL AID TALKGROUPS (Law Enforcement Agencies Only)
NAME DEC ID HEX ID
LAW ENFORCEMENT CALL LECALL 800435 1B3
LAW ENFORCEMENT COMMON 01 LEMA01 800443 1BB
LAW ENFORCEMENT COMMON 02 LEMA02 800451 1C3
LAW ENFORCEMENT COMMON 03 LEMA03 800459 1CB
LAW ENFORCEMENT COMMON 04 LEMA04 800467 1D3
LAW ENFORCEMENT COMMON 05 LEMA05 800475 1DB
LAW ENFORCEMENT COMMON 06 LEMA06 801301 515
LAW ENFORCEMENT COMMON 07 LEMA07 801309 51D
LAW ENFORCEMENT COMMON 08 LEMA08 801317 525
LAW ENFORCEMENT COMMON 09 LEMA09 801325 52D
LAW ENFORCEMENT COMMON 10 LEMA10 801333 535
Law Enforcement Talkgroups are monitored by SC Department of Public Safety and distributed to users for special events by Nick Babin at South Carolina Highway Patrol.
RECOMMENDED CONVENTIONAL MUTUAL AID CHANNELS
National Mutual Aid Channels
NAME TRANSMITT RECEIVE PL TONE
ICALL 821.0125 866.0125 156.7HZ
ITAC-1 821.5125 866.5125 156.7HZ
ITAC-2 822.0125 867.0125 156.7HZ
ITAC-3 822.5125 867.5125 156.7HZ
ITAC-4 823.0125 868.0125 156.7HZ
South Carolina Mutual Aid Channels
SCTAC1 821.2250 866.2250 156.7HZ
SCTAC2 821.6875 866.6875 156.7HZ
SCTAC3 822.7750 867.7750 156.7HZ
SCTAC4 823.6375 868.6375 156.7HZ
SCTAC5 823.9750 868.9750 156.7HZ
POLICY FOR MUTUAL AID TALKGROUPS AND CHANNELS
All Mutual Aid talkgroups (Regional, Statewide & Law Enforcement) and Mutual Aid conventional repeaters shall not be used for routine daily operations or as ongoing working channels by any agency. These channels shall be reserved for inter-agency communications, incidents requiring multi-agency participation, coordination and emergencies. These shall not be used for administrative or intra-agency communications unless so directed during a major emergency or disaster situation.
All use of Mutual Aid Talkgroups or Repeaters for special events are to be coordinated with the appropriate agencies.
Assignable Regional Mutual Aid Talkgroups - Coordinate with EMD
Statewide Mutual Aid Talkgroups - Coordinate with EMD
Air to Ground Talkgroup - Coordinate with EMD
Law Enforcement Common Talkgroups - Coordinate with S.C. Highway Patrol
(Nick Babin)
ITAC and SCTAC Conventional Repeaters - Local County Dispatch Center
(EMD will coordinate with Motorola and the CIO’s Office on the use of all Mutual Aid Talkgroups. Motorola will reconfigure the talkgroup assigned for the special event to provide only the coverage needed for that event.)
Special event use of an 800MHz conventional repeater(s) is limited to the SCTAC frequencies ONLY. Special event use should be coordinated with the agency providing direct control of the Mutual Aid channel. Use of the channel shall not interfere with emergency or disaster situations. If an emergency or disaster situation develops the agency providing direct control of the Mutual Aid channel(s) under its authority may terminate the Special Event Use of the Mutual Aid channel.
Plain ENGLISH will be used at all times on all Mutual Aid Channels. The use of unfamiliar terms, codes or signals is not allowed.
The use of ric switches or console cross-patching is not allowed on any of the Mutual Aid Channels.
Telephone interconnect (i.e. telephone patching) is prohibited on any of the Mutual Aid Channels.
