Mystery Chinese radio
telxonmaster
Southwest Missouri
millrad
Connecticut
Does the radio have a typical female jack to plug in a charger, or does it require a drop-in charger? If its the first case, rigging something up should be easy enough. Interesting radio, resembles something in the Yaesu family.
KB0VWG
Lyford, Texas
I had one
Looks like a puxing px777.
Sent from a rotary phone
I had one of those too and I believe it is a puxing too, It is a real pain to find ctcss codes because they are numbered does not show the tone itself. I looked online and did find a chart telling what numbers corresponded to the tone freq.
I sold it it was a pain to cross reference on what tones you needed by using the chart.
kb0vwg
wqoi992
And I don't remember where I got mine either
telxonmaster
Southwest Missouri
It does look like a Puxing 777, maybe an older one. It takes a drop in charger, unless it can charge through the ear or mic jack, and I doubt it can. Probably not worth finding a charger for it, as my friend never used it, so I have no clue if it even works.
telxonmaster
Southwest Missouri
I actually just popped the battery case apart, and the crappy soldered connections promptly came apart! I decided to make this a project radio, maybe couple it to an Arduino or make a node of some sort. I soldered leads onto the empty battery case, put 8 volts to it, and voila, it powered up!
