Kingmobileaudio
I'm out of Lincoln and need help picking witch systems to program in to my 996xt with an out door antt.
I think you posted in the wrong area?Did you look at this? At first glance it looks like all conventional frequencies. Lancaster County, Nebraska (NE) Scanner Frequencies and Radio Frequency Reference
I get Lincoln, Norfolk, full signal. Milford 0-2. This is a base setup with an outdoor antenna. And I never hear anything.Use the Lincoln and Milford Towers control channels and that should get what you are looking for.
Dunno if you are actually getting Norfolk clear down there in Lincoln. Norfolk on 155.5875, Lincoln on 155.5900, you are probably getting the "bleedover" from Lincoln, since Norfolk and Lincoln are so close together in frequency.I get Lincoln, Norfolk, full signal. Milford 0-2. This is a base setup with an outdoor antenna. And I never hear anything.
