N8DRC shack
N8DRC
Grass Lake
Well it has been a while since I last posted my shack this is my latest set-up..
Scanner's
2 Stridberg MCA 204 A multi-coupler's, 2 GRE 3001 Pre-Amp's, Realistic Navaho, Pro-2052, Pro-2053, PSR-500, Pro-96, Pro-83, Pro-2096 x2, Pro-2045 x2, Pro-2051, PSR-600, Pro-2035, Pro-2067, BC780XLT, Pro-2006 (lots of mods) BC895XLT, Pro-41, Pro-34, Davis Weather Wizard 3 with rain guage..
Ham
HTX-202, HTX-404, FT 60-R, FT-7800R, Icom IC-718 w SM-20 mic, MFJ-949E tuner, HTX-10 meter..
Antenna's
30 feet of Rohn 25G, Cushcraft 13B2 Boomer, Hy-Gain TH-3JRS Beam, 102' G5RV True-Talk inverted V dipole, Yaesu G-800SA Rotator, MFJ-1798 Vertical, Tram 2m/440 vertical, Scantenna x2, 2 Wilson 301111 800mhz yagi's, RS 20-176, Weingard all band antenna, Solarcon A-99 x 2..
Mobile
Yaesu 8800-R, Pro-197, Galaxy 949, my wife also has a 7900R in her mobile..
commscanaus
Melbourne VK
Yep! I love it!
Lots of radio's, nice and neat with the ability to listen to just about anything.
The under desk lighting is very effective.
Your antenna system is as neat as pin too! The dual scantenna's are well placed.
Regards, Commscanaus.
scannersnstuff
a beaut. of a setup !. with the stridsberg run to the gre amplifier do you have any problem's with overload ?.
i'd get crushed with mine like that.
WatnNY
Knoxville, TN
I am soooo jealous! Talk about being able to listen to everything under the sun!
Mike
N8DRC
Grass Lake
No I don't have any problems, I have one open about 3/4 on the gain control, and the other I use for 800mhz I have that one set to the min. I live in a very rural area and don't have any interference close by..Thanks for the comments guys..
N8DRC
Grass Lake
800 yagi's
Here is a photo of my wilson 800 yagi's and the 2/440 tram both are fed with lmr-400, also the rain sensor is mounted on the tower..
kevin390
Wallkill, NY
Dan,
This is got to be the cleanest most professional site I have ever seen. I am not knocking anyone else, because there are allot of great shacks here. But your shack looks like you work for the C.I.A. or NASA. Great job my friend you should be real proud............Ray
jrule
Wow!!!!!!!!!!!!!!
WoW LOOKS GOOD. I really like the desk too. must be custom build.
