N9JIG Addition by Contraction
N9JIG
Sheriff
Moderator
Far NW Valley
So over the last couple of years I realized that these days I really do not need the couple dozen scanners that I used in the past. I have pared things down to what I actually use all the time. In addition I have obtained a few new toys that serve a purpose.
First off a little bit about the layout of the office. It is perfectly laid out for my needs. It is off the living room and I have my desk placed so that I can see and communicate with the wife while she sits in the living room, it helps us to keep doing our own things while still being together. In addition the TV monitor for our security cameras is easily visible from her favorite seat on the couch so she can see if something is going on around the house. We have specific reasons for this.
In addition to that monitor I have 2 additional wall-mounted TV's that I use mostly for entertainment. I usually run live streams of rail-cams or airports but can also watch TV or movies if I want. All 3 screens are 4K 50-inch displays.
My main desk itself is devoid of radios save for the control head and mic for my main HF rig, an Icom IC-7000. I also use it for 2M and 440 work, including a couple local nets I participate in. The desk itself is a SecretLabs Magnus ProXL all-steel standing desk. It has a neat wire channel at the back to hid wires (I hate seeing wires). I do run ProScan to watch the scanners and log activity from my desk.
Slung underneath the right side of the desk is my main PC, a homebuilt beast with a Ryzen-7 7800 CPU, Asrock Radeon RX6600 GPU, 64 GB of RAM on an Aorus X6700 Elite MB, with 16TB of SSD storage. It drives three 27-inch Acer Nitro 170 Hz HD monitors. The monitors are on SecretLabs arms, I am waiting on the parts to use a single pillar to support 4 monitors. Under the desk on the left side is a UPS to protect the PC.
The Radio Desk is my wife's old standing desk. When the motor gave out I used it as a workbench in the garage for a while and will probably replace it with a HomeDepot cranking desk that is a little wider and allows it to sit lower. The casters on the new desk would allow me to easily swing it out to work on the back of the cabinet, but for now this smaller desk is working well.
On the desk is my 4u/3-bay AudioRax Slant cabinet that I have used before. In the left bay are 4 BCD536HP's. In the center bay is my Zetron Model 27 audio controller. In the right bay is an SDS200, BCD996P2, AnyTone AT-578UV-III and a 50-amp Astron power supply with meters.
On top of the cabinet from left to right are my Icom R8600, Scanner Master RH200 prototype, Motorola Astro Railroad Spectra (reprogrammed to also include some 2M frequencies), my IC-705 and my SDS100 and stand.
Inside the cabinet is a Stridsberg 8-port multicoupler, a 13-port USB hub and a PowerPoles block.
On the back wall left is a drawer cabinet with a 4u AudioRax Turret Rack. This has my network switch and firewall as well as an SDR streaming system I host for a friend. There is a Noctua fan to keep the SDR's cool, they really run hot without it.
Next to that is a Husky (HomeDepot) toolchest. In the drawers are my portable radios, some small tools, computer cables and the like. On top are some of my portables that had desk chargers, including my Icom R30, AnyTone AT-D878UVII (I have 3...) and an Icom ID-52A.
On the back wall are oversized prints of the charts for 3 airports (PWK, ORD and PHX) as well as the propeller from my dad's plane.
I still have several radios available or set up in the garage., like another SDS200, a BCD160DN and a couple 996XT's and BCT15X's. As for other handhelds I have a 436, a BCD325, a 125 and a BCD260DN as well as a pair of Icom R5's and my IC-7300.
This smaller shack seems to fit my current needs. I use the SDS200 to monitor the local P25 systems, the 536's are used for things like local aviation, CloseCall, railroads etc. and the 996 is used mostly for GMRS monitoring.
The RR Spectra is used to monitor my local BNSF Road channel and sometimes on the 2M nets. It has remarkably good transmit audio and I am lucky to have a friend who can program it for me. I got it at a hamfest a while back for $20, the seller had no idea what it was and was happy that someone could use it. It was in pristine shape. I modified the power connector to PowerPole and added an on/off switch.
For the future I suspect I will be getting a new maxed out Mac Mini soon. It will become my main desktop computer and I will move the existing PC to the other desk. Via RDC I can still maintain a watch on things from the main desk but will likely put a monitor on the radio desk to support the radio programming and ProScan. I am still a Mac guy at heart and while the last two years of using a PC as my main computer has been fine I really prefer the MacOS lifestyle.
Let's see how long this layout lasts!
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
If I had the width space I would totally do the 4u/3-bay AudioRax Slant cabinet and mount my Zetron Model 27 in the middle like yours. (y) I'm still using the Havis 24" Mobile Console as a desk tower with 7 Radios and scanners.
prcguy
Very nice! And the super organization suggests some mental processes most of us don't posses. I noticed the handles on the R8600, are those from Scott? If so they are my invention originally for the Elecraft K3 then expanded for some Icom models.
N9JIG
Sheriff
Moderator
Far NW Valley
They are the SideKX panels. I have a set for the 7300 (stored for now) as well.
N9JIG
Sheriff
Moderator
Far NW Valley
I had plans at one time to get an IC-9700 to go with the 7300 and R8600. Would have looked great but the 9700 was totally impractical for me. I would have had the SideKX panels for that too if I got one.
prcguy
Who is this fellow Scott? I want sides for my K3?
Scott is a friend of mine who went into business making side panels for the Elecraft K3 then the KX3 and KX2 using American ingenuity and American aerospace metal fabricators, plastic fabricators and silk screen shops. He then expanded to some Icom models which I noticed on N9JIGs radio. Then all the copy cats went to work in the US and China copying what Scott does but with lower quality. Apparently N9JIG is very quality conscious as his station pics show.
N9JIG
Sheriff
Moderator
Far NW Valley
Nice setup. Do you use any kind of battery backup?
Not for the radios as I have plenty of handhelds should they be needed. The computers have a UPS to allow a graceful shutdown in case of a prolonged power loss. In the 10 years I have lived here we have had 2 outages, the first about 8 years ago when a high-tension line nearby came down that lasted a few hours and the other lasted almost a full minute a year or two ago.
BinaryMode
2600 dialtone blvd
Yeah, I don't get a lot of power outages either, but every once in a while, especially during the Winter, the power flickers for a split second. So it's good to have a UPS to maintain a steady flow of power to the computers.
Being active on many tech forums, I can't tell you how many times I read someone's computer bit the dust thanks to a power outage. It's like an abrupt power loss sometimes messes up the PSU or motherboard. Possibly corrupting the hard drive. I had that happen to a power supply to a Dell Mini 910 that I had connected to an external monitor and keyboard in the kitchen. It was the "Kitchen Kiosk." It also used a caller-ID capable dial-up modem to pass CID data to the Phonetray application that was like a firewall for my POTS phone. I still use it inconjunction with Ooma and their offerings. So now I have two home phone firewalls. LOL
I'd like to build a better battery backup. One that uses a 100 Ah LiFePo4 battery, pure since wave inverter, high quality LiFePo4 charger, and an automatic transfer switch. Something like that will cost me around $350 I suppose. Just have it on the back burner.
The TVs you have. Are those online feeds?
Edit-
Actually, one monitor looks to be home cameras and a network video recorder.
prcguy
Edit-
You live in the desert, why not solar for charging your 100AH LiFePo4? I have about 400w of solar panels charging a couple of 90AH sealed, gas regurgitating ALM batteries that powers lost of radios and repeaters in my garage. I had 440AH of golf cart batteries for a couple of years but they broke....
CKnobb
Central NY
I'm always excited to see shack photos, especially yours. I am super impressed by the cable management. That has always been my Achilles heel. I get the radios, the monitors and assorted accessories neat and tidy, but my cabling and coax is all exposed and basically a chaotic rats nest.
