N9JIG Contracts even further for July 2025
N9JIG
Sheriff
Moderator
Far NW Valley
It has been almost six months since I last posted a redone shack photo post. That has to be some sort of record! I tend to rearrange my shack as often as Scott @KC1UA buys and sells R8600’s. Over this time, I took stock in what I actually used every day and what I didn’t. I realized I really only needed a few scanners and other radios these days and again reduced the number of radios in my shack. My last shack photo series was also a contraction; I have now taken it a bit further.
A couple factors went into the layout and radio selection. First was what my needs were. I have devolved into mostly listening to railroad, aviation, GMRS/FRS and the local community and HOA. I have also gone back to recording some stuff for future review and dug out my old PL decoder as it is easier to view than the tiny display on the scanners. This is very useful for some of the GMRS and FRS activity around here that I am currently interested in.
The next factor was my antenna situation. I have a boatload of antennas in my attic as well as a single external antenna on my HOA home. As far as the HOA is concerned this is a TV antenna and that is all I have to say about that. Due probably to some issues with the coax leading to it I have found that either an Omni-X or ST-2 is majorly outperformed by a Diamond DX200 in my attic as well as a Comet GP-1. It is too hot for me to get up into the attic to replace the coax so for now I will use the Diamond. I have it feeding a Stridsberg 8-port multicoupler so decided to restrict myself to 8 receivers.
First off, a reminder as to why I use a cabinet: Wire Management. I hate seeing wires. Remember that episode of “Friends” where Chandler discovers Monica’s messy closet? Well, that is the rear of my cabinet. With 10 radios, all with USB cables, power, antennas and others with accessories like an Auto-tuner or audio cables there are a lot of wires. Since I am no longer using the Zetron Model 27 I have been able to eliminate a bunch of cables but there are still a lot. It looks messy but it is a lot better than it was. I need to replace my antenna jumpers to the patch panel with more flexible ones but that is a problem for future Rich, for now I have to deal with gentle curves. The great thing about a cabinet is that I can stuff the wires out of sight. It is sort of like a mullet, all business up front and a playground in the back. This set up makes it really easy for me to swing the desk around to access the back to swap out a cable or something.
That 8-receiver restriction led me to decide on 6 scanners; the other two ports are used by my R8600 and a Railroad Spectra. I decided to go with symmetry in my cabinet layout as aesthetics are important to me. I am using my 10u AudioRax cabinet that has been featured here before. Of course, I still have my 3u/3bay and 4u/3bay cabinets stored in the garage for future use.
By the way Scott: I still have my first (and so far only) R8600. Chew on that buddy!
So for my new layout I have 2 SDS200’s on top, 2 BCD536HP’s next and 2 996’s below. I moved the power supply down and have a blank panel at the bottom of the cabinet. I took the dual-band AnyTone out of the cabinet, it now lives on top of the cabinet. I have retired and stored the IC-7300 and IC-705 as well as the Zetron Model 27 but will retain them for future use down the road. Since I bought the IC-7100 I found I really like it as a desktop radio!
The iPad is used for home automation, a Zello network used by some friends and the occasional sojourn to my Lazy Boy to watch a movie, I can usually get past the credits before I fall asleep. Next to it is the head and mic for my IC-7100. I use this for my ham radio needs; I can do some pretty decent 20M stuff as well as 2M and 440. To the left is the Railroad Spectra with the R8600 on top and my SDS100 above that.
Below the 6 scanners is the 12V/50A Astron power supply with metering and my CD-1 PL decoder. The CD1 is connected to the 996XT and the 996P2 is connected for recording to the PC.
In this wider view you can see a portion of my handheld radios, some in desk chargers and others on a wood rack that was gifted to me by my friend Will. It came from a creator on Etsy (Flather Creations) who designed it to our specs. Remove the radios and it looks like a park bench. There is a slot the width of the stand so you can run charging or computer connections to the side of the radios. With no such cables it holds 5 radios, put a couple serial, power or USB cables and you are down to 4.
Next to the radio cabinet is a steel monitor stand that holds the RR Spectra and other radios. Under the shelf is the box for the 7100. I used to leave this in the cabinet but relocating it here allows more space in the cabinet for stashing wires and makes it easier to access said wiring. I think it should also reduce heat issues down the road.
The radio desk is a Husky (Home Depot’s house brand) workbench with 2 drawers. It has a hand crank so I can raise it if needed. It is sturdy, durable and the drawers allow me to keep some small tools and accessories at hand. I had a taller tool chest in the office before but most of the stuff stored in it lived better in the garage so now I am actually using it in the garage for tools as it was intended.
This is my main computer desk. I can rotate my chair to the left to get to my radios. The smaller display is for the Windows computer used mostly for programming radios and running ProScan, Butel, Scanner Recorder or ham radio stuff like FT-8 now and then.
The 49" UltraWide monitor is for my main computer, a Mac Studio I got a few months ago. I had switched to the Windows computer for my daily driver for a year or so but really missed the Mac (“Once you go Mac, you never go back”!) I use separate mice for the two computers, but they share the keyboard. The chair is from LF Gaming and cost me twice as much as the desk.
Above the computer is a 50” 4K TV, one of 3 on different walls of the office. I usually run a stream of an airport or rail cam here, today is during Oshkosh 2025 so I am watching the parade of flights in and out. When I took this picture the other day however I was running my GeoChron. I have another similar display to my right on the other wall that I also use for watching streams and a third on the back wall I use for my security cameras.
The desk is from Secret Labs, it is the Magnus ProXL, sit-stand desk. This thing was (and remains) my dream desk. It has the best wire management scheme I have ever seen on a desk. Using a full width tray along the back to hold wires, power strips and bricks, small accessories like hard drives and hubs, it keeps all the wires out of sight. It had a heavy-duty power cable that plugs into the base of the left leg that powers the desk and an outlet stashed in the wire tray. If it weren’t for the network, audio and USB cables in my build it would be entirely self-contained. I have the optional CPU holder on the left leg for my big PC case, along with all the magnetic wire management accessories (the desk is all steel) it really is a great desk for gamers, productivity and even radio. I have had my radio case on it before, it had no problem holding it, but for now I like it the way it is. I might end up doing that again down the road and use the Husky as a work bench like it was intended. Who knows?
Any bets on when I tear it all down and rebuild again? Being retired gives me more time to dream and build…
phoboss1
TX
I like the "Scanner Master Early Prototype" shown in the 2nd-to-last picture.
KC1UA
Scan New England Janitor/Maintenance
Lookin' good as always. I think my current 8600 has the longevity record. If I were to get rid of it, the entire apple cart here would be out of whack, so it's here to stay this time (I think). Love that ultra wide monitor. I will not buy one I will not buy one I will not buy one I will not buy one....
wa8pyr
Lead Database Admin
Ohio
Still got my first (and only) R8600 as well, so HA!
Recently purchased a second SDS200, so now I have two SDS200s for trunked simulcast monitoring; right below those I have two Pro-197s, one for my local non-simulcast county and the other mostly used for control channel monitoring with Pro96Com); finally there are two BC780XLTs, one used for railroad monitoring and the other for aviation monitoring.
There's an empty shelf below those which currently holds a DMR ham transceiver which never gets used and which may receive a Harris (et al) M7100 for real manly railroad monitoring. Finally there are two XTL2500s for VHF and UHF ham use.
Retired an IC7300 and IC705?!?!? Heresy!!!! Burning at the stake is too good!!!
Tom
N9JIG
Sheriff
Moderator
Far NW Valley
Tom
I still have them but they just aren't in current use. I use the 705 mostly on the patio in the cooler months but originally bought it for POTA but never got around to that. The 7300 is a cool radio, I originally planned on getting the matching IC-9700 but even I couldn't justify that purchase, the 7100 does everything the 9700 and 7300 would do for me and then some.
AK9R
Central Indiana
I like the enlarged prints of the airport diagrams. That's a neat idea. Useful reference, technical "art", and conversation starter for visitors. Of course, my OCD would force me to turn the Sky Harbor print horizontally since the runways are mostly east-west. ;)
N9JIG
Sheriff
Moderator
Far NW Valley
Yeah, but then MY OCD would have to have all three frames the same orientation, plus the text would be wrong.
It bothers me that I cannot seem to get the three frames perfectly aligned. There are several holes under each frame stemming from my attempts to align them. My painter is going to have a field day with spackle this fall.
AK9R
Central Indiana
Hmmm...the ORD airport diagram appears to be oriented correctly. But, I don't recognize the airport on the left.
N9JIG
Sheriff
Moderator
Far NW Valley
PWK, Chicago Executive. Used to be Palwaukee. I grew up nearby and hung out there. Got a ride on a Lear Jet when I was 10 and hanging out on the flight line, can't do that these days!
SABER3
Saber3
How did you get those prints of the Airports? They look nice.
TY for the 411
rgchristy
Delco, PA
I always look forward to Rich's shack posts...
Whenever I want to buy something, I show her his posts and tell her how I could be...:ROFLMAO:
But seriously, amazing setup!
merlin
DN32su
Very nice, and another aviator enthusiast.
I like the chair.
iggywfd
The Villages Florida
Rich,
I too on working on resetting my shack here in FLA, unfortunately everything in this area is that dreadful ENC!!!! Yuck! I miss all the great folks that I met through SM but Scott is doing a great job filling our roles....
John W
KC1WAB
FedFyrGuy
Hagerstown, Maryland
Used to love taking the kids to the 94th Aero Squadron Restaurant nearby, they had headphones at many of the tables so that you could listen to the airport traffic.
