Here is a shot of the mobile install in my vehicle.
From top to bottom:
RH-96 Remote Head connected to a BCD996T
BC796D
BC15
CDM1250 UHF
CDM1250 VHF
CD-1 Tone Decoder
On the right side of the console is the control head for my Kenwood TM-D700 dual bander.
Out of sight below the RH96 is a Garmin GPS used for the BCD996T. The BCD996T is tucked away between the passenger seat and console below the dual band control head.
The RH96 is actually mounted on a pull-out cup holder, pushed in the control head is almost flush with the stereo above it (as shown), pulled out the cup holders are clear and unobstructed and the RH96 is pretty close to and aligned with the 796.
The 3 mics are remoted with Cat 5 patch cables to a patch box on the back side of the console, that is the white box below the Moto mics. This helps avoid cord tangles. (I plan on spray painting this box soon to match the console)
The console is a Troy Command Console I picked up at a hamfest. It had no side rails or inserts when I bought it and it was in pretty rough condition. I did some patch painting and sanding off some rust spots, and replaced the side rails with aluminum stock.
There are 3 power leads, 2 directly to the battery for the CDM's and another to the accessory port on the interior fuseblock for the scanners and TM-D700. With the CDM's turn-on leads connected to the accessory port they turn and off with the ignition, and I can turn them on manually with the engine off.
I have 4 antennas on NMO mounts to the rear of the van. One is a dual bander for the TM-D700, one each as 1/4 waves for the CDM's and an Antennex center loaded scanner antenna for the 3 scanners. This feeds a Stridsberg amplified multi-coupler enclosed in the console. Directly below the UHF mic is a panel mount BNC that can be used for a handheld scanner when 3 just aren't enough.
I am waiting on a panel to replace the jerry-rigged arrangement for the CD-1, when it arrives from the shop I will take a Dremel tool to it to fit the tone decoder.
There are cigar plug sockets on the right and left sies of the console that are not visible in this picture.
I didn't notice that the displays were pretty much wiped out by glare when I took these pictures, they looked fine in the view finder!
From top to bottom:
BC796D
BC15
CDM1250 UHF
CDM1250 VHF
CD-1 Tone Decoder
