(NAF) Monitoring METROLINX GO Transit Using an XTS 2500
BaofengUV82L
TORONTO Ontario, Canada
Hope this doesn't sound dumb but is this POSSIBLE? I believe if programmed and flashed correctly in theory an XTS 2500 UHF should be able to pickup the talkgroups in RR marked with a D but not those with a T. Does anyone have any insight on this? What flashcode would be required? Thanks
K2NEC
Is it possible? Maybe.
Does it mean you should try it? I'd advise against it.
BaofengUV82L
Yes, it’s doable.
>Yes, that's what I want to hear!
There’s very few non-TDMA groups on the system though.
>Those are the only ones I want to monitor. Just those select few.
Post a link to the system and provide the exact specs on the radio.
Here is the (link to the) system called
"Metrolinx - GO Transit"
System Type:Project 25 Phase II
System Voice:APCO-25 Common Air Interface Exclusive
As for Radio Specs. This is an XTS 2500 UHF (403-470Mhz) so called model I but it does Have a screen and no key pad. Here is a pic of the back..BUT..In an effort to go 'on' err monitor I should say the "Metrolinx - GO Transit" system, I upgraded the radios firmware and tuning partitions using a certain windows program to the following:
Sys.Pkg: SMARTzone
FLASHcode:500008-000488-2
Firmware : 20.50.09
Tuning: R01.08.14
DSP: 19.50.01
Sys.Pkg: SMARTzone
Firmware : 20.50.09
Tuning: R01.08.14
DSP: 19.50.01
chrismol1
P25 TruCking!
Sys.Pkg: SMARTzone
Ahh came in coy yet got the exact one needed. Very nice young padawan, learning you are
You can set all the channels, the red & blue ones are reported as CC's, its possible channels change, you can program them all in, theres only a handful per site unless have an SDR, scanner to verify for sure, the radio will find the control channel. If you travel, it will find the new towers control channel within range by adjacent site or programmed control channel.
Set it to Smartzone, check off Omnilink for good measure, or the Site IDs/RFSS matter (Yes I know 1 is the only RFSS listed), digital modulator CQPSK, I'd set the Ultra Narrow Intermediate Frequency Filter to 5.76
Do you know the channel ID band plan for this system? Looks like theres base freq in the wiki. For pure purposes, I'd set the concentric switch to TX Inhibit. I haven't had a problem receiving with it on
chrismol1
P25 TruCking!
Utterly pointless.
You do you, I know it works and its not needed for advanced users, but I would suggest a total noob enable it while they ultimately screw things up trying to do it the first time. It would be far from the first time noobs park it on the talkgroup and not a conventional channel or setup the wrong site IDs and RFSS
Outerdog
T¹ ÆS Ø
The problem is you don't bother to explain why it's not needed. You say to turn on Tx Inhibit, leading the noob you're so concerned about to likely believe that Tx Inhibit means "I"m good". Your smug little "learning you are" Yoda garbage is more important to you than taking time to post some useful information for your noob.
For the OP, Tx Inhibit is useless because it does not prevent the radio from transmitting inbound signal words to the system or responding to interrogatives from the system. It does not prevent the radio from attempting to affiliate.
What it does do is prevent the radio from sending a channel grant request (PTT) -- which, if you've already parked on a trunking talkgroup personality, you've already failed the mission. The radio has already transmitted and probably affiliated.
GTR8000
NY/NJ Database Guy
BEE00
Wrong. When the concentric switch is set to TX Inhibit on the XTS 2500/5000 and all APX models, it prevents ALL transmissions: registration, affiliation, acknowledgements, transmitting, etc.
If you're going to call out another member, perhaps you ought to get your facts straight first.
chrismol1
P25 TruCking!
Further what those who don't realize is if you do NOT select Smartzone and Omnilink and don't have tx inhibit, if you do not get the correct Site ID or RFSS the radio will try to transmit even in non affiliate scan on a conventional channel with trunked scan list, this is something never discussed and why scanners are better for noobs. There is a lot to learn when using a motorola. The NAF scan instructions are for people who already know a trunked system. This is something nobody bothers to mention when noobs that leave it on Disabled
TX Inhibit has no affect on 9600 Astro systems scanning from a conventional channel. Its preferable for noobs who regardless of everyone telling them to buy a scanner will do what we don't want to do anyway and allows you to figure out whats wrong without transmitting which everyone on here realizes is the correct way to do things, not to trespass on a system. Program for TX Inhibit concentric switch and do your experimentation that they will do regardless. I hope this will be archieved for future users
BaofengUV82L
I am not a TOTAL nube, but I always did wonder (when I open up other people's Codeplugs and see that they have set the concentric switch to Tx Inhibit) if setting it like that served a purpose.
He is also going to need the BP and a SYSkey. I hope the OP knows what hes doing. I would hate to see him get in trouble.
Already I made the system Key and loaded it. What is the BP?
And be sure to use radio ID 1.
Seriously? That way just in case it affiliates it wont mimic a real ID?
Wow! A real answer! Those are exactly all the little details I need help with As the radio is still not talking just I didn't Want to be a noob and ask all that.. I will try again tomorrow. I do not know/fully understand The channel band plan for this system. I did look at the wiki but the format they put the numbers in gave me no real.clue where to enter Them etc
N4KVE
PALM BEACH, FLORIDA
Sys.Pkg: SMARTzone
Firmware : 20.50.09
Tuning: R01.08.14
DSP: 19.50.01
Sys.Pkg: SMARTzone
Firmware : 20.50.09
Tuning: R01.08.14
DSP: 19.50.01
It’s a model 1.5. A model 1 has no screen.
northstarfire0693
North Carolina
You will need to know the channel BP to get the radio to work or else you wont hear any talkgroups. The BP are not posted on any website that I am aware of. The best way to get it is to use unitrunker. It will show you the BP as well as other system info.
