Narrow band list
N0ZQR
Is there some where on the Web that lists the radios that are narrowband conmpliant?
Any help would be great!
Ron
radioman2001
New York North Carolina and all points in between
Generally anything built after 1999, and some as early as 1992. For your own research take the FCC id and use this: OET -- FCC ID Search
Also BTW as of 4-19-2012 T-band radio's and frequencies do NOT have to be narrow banded. If you have a mixture of T-band and non T-band frequencies in that radio then the non-T have to be narrow banded. The FCC changed it's mind, due to a proposed giveback, which I hope doesn't happen, unless they want to give me some free and clear channels somewhere else.
ipfd320
Banned
W.Babylon N.Y. 11704
Thats a Hard Call Since There are so Many Makes and Models that were Produced thru the Years...According to the Mandate if i Read it Correctly Anything from 1996 and Lower is Not NARROWBAND Conpatiable....but Like I Said it Depends on the Manufacturer and the Componenets that were Used
ipfd320
Banned
I Just Found this Page on a Search:
RADIO GUIDE
Existing Radios that meet new Narrowband Rule (12.5 KHz spacing)
These radios can be reprogrammed to narrowband and are A-OK:
Locomotive: Motorola Railroad Astro; Ritron RCCR; JEM; GE 12R
PORTABLES--- Motorola: P1225, HT1000, MT2000, MTS2000, JT1000; HT750, HT1250, EX500,
EX600, XTS Series, CP200, CP150, PR400, PR860, PR1500, MT1500, CP185, CP110
KENWOOD--- NX200, TK5210, TK272G, TK290, TK2140, TK2180, TK230ZVK; (Following
models must have "N" suffix) TK240N, TK250N, TK260N.
ICOM---- IC-F50, IC-F11, IC-F14, ICF3G, IC-F3021, IC-F33G, IC-F30GS.
VERTEX---- VX-160, VX-180, VX-210, VX-310, HX292UT,
VX-400, VX-510, VX-800, VX900, VX600; VX-231, VX-350, VX-410-420; VX510/537, VX-820,
VX-920, VX-P820, VX-P920
MOBILES:---- Motorola: M1225, Astro, CM200, CM300, PM400, CDM750, CDM1250, CDM1550,
XTL Series (all), PM1500.
KENWOOD---: NX700, TK762, TK2160, TK2170, TK5710, TK7102H,
TK7150, TK7160, TK7180
ICOM--- IC-F121, IC-F5021, IC-F521, IC-F721, IC-F5021.
VERTEX--VX-2100/2200, VX-4100/4200, CNT-5000, VX-5500, VX-6000, VX-7100/7200, VX-2000,
VX-2500, VX-3000, VX-3200, VX-4000.
Base/Repeaters:
Motorola: XPR8300, R1225, MTR2000,
Kenwood: NXR7000, TKR750, TKR(B)751, TKR7400, TKR7500.
Icom: IC-FR3000, IC-FR5000, IC-F121S.
Vertex: VXR7000, VXR9000, VXR1000.
These radios must be replaced:
Locomotive: Motorola Railroad Spectra, Motorola MCX100, Harmon Trackstar, Aerotron
PORTABLES---- Motorola: HT600, MT1000, GP300, GP350, P100, P110, Saber, P200, SP50, HT50.
KENWOOD---- Any radio with "W" suffix: TK240W, TK250W, TK260W. Vertex: FTH-2070, FTH-
7009, VX-200, VX-300, VX-500.
MOBILES--- Motorola: Maxtrac, Maratrac, GM300, M100, M216, M208, SM50, Syntor, Spectra,
Micor, Mitrek
KENWOOD---- Any radio with "W" suffix: TK702W, TK705W, YK760W, TK740W,
etc.
VERTEX---- FTL-2011, FTL-7011, VXR-5000.
Base/Repeaters: Motorola: MSR5000, MSF5000, R100, Desktrac. Kenwood: TKR720, TKR740
N0ZQR
Cool! Thanks for the help, so far.
Here's why I ask the question. I have been give a list of radios by my county and they are asking which radios will need to be replaced and which ones just need to be "narrowbanded".
They are a mix of Kenwood, Standard, Motorola, Uniden, Rengency you get the picture.
Hope this helps.
Ron
radioman2001
Our agency has nearly 4000 radios, I found that even some with the same model numbers were and some were not, based on the FCC ID. If you have a list of your radios, it may be easier to just run the FCC numbers. I also noticed a lack of GE/Harris radios listed out there, and there also are some radios that may have had narrow band kits made for them, but still don't meet the guidelines. Better be safe than sorry, run the numbers through the FCC database.
