Narrow Banding questions -
lbpd719
37.02855 -120.872629
Hi folks -
I have been tasked at work to develop a "white paper" regarding the 2011 / 2018 rebanding issues.
Does anyone have a good idea of where to start? I am posting this here because I am sure this mandate will cause major changes to the databases here..
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
I moved this to the system manager's technical forum
lbpd719
Another good source =) thank you.. The fun part for me will be getting this into an administrator readable form.. Anyone have any recent migration info they care to share?
studgeman
Well in short, in 2013, less than 5 years from now, all part 90 users (you) will be required to modify thier radio systems to use less spectrum, or narrowband. This change is helping to free up some badly needed spectrum around the country. For most agencies to narrowband it requires equipment changes of receivers and repeaters and also portables and mobiles. Most equipment that has been manufactured in the last 10 years is capable of narrowband operation, and just needs to be programmed. An examination of your system by your radio shop or outside consultant can help determine what your needs are to convert to narrowband. Many agenies are using this opportunity to fund a capital project to improve coverage and reliability of their systems.
mrdinks
Iowa
Go to the FCC web page and search, We just went through the narrow banding and there is a lot of info about it.
zerg901
yup
Nick Ruark over at the PublicWirelessForum at Yahoogroups has a paper about narowbanding that he shares freely. Check the Files at that group. It might be exactly what you are looking for. Peter sz
zerg901
yup
I am not sure if the terminology is clear here. I think that the FCC uses -
'reconfiguration' in connection with moving the public safety users at 866 thru 869 Mhz to 851 thru 855 Mhz
'narrowbanding' to indication the conversion of channels between 150 Mhz and ? 506 Mhz to 11K3F3E "narrowband" emissions
refarming - ?? - changing channel spacing and mountain top ERPs between 150 Mhz and 506 Mhz
rebanding - ???
Just something to keep in mind as you do your research.
Peter Sz
AlanTilles
Quick Clarification
Just one quick clarification. It is not ALL Part 90 channels that must narrowband. Basically, we're only talking about the VHF and UHF bands. Narrowbanding does NOT apply to: (1) the 150 and 450 MHz paging-only channels; (2) the 800 MHz band; and (3) the 900 MHz band.
I believe that this is an important issue to bring up, repeatedly, as some salesman have gone to 800 MHz licensees and said that the licensee should move to 150 (or 450) because they had to narrowband their 800 MHz system anyway, which is not true.
Alan
nbruark
Re: Narrowbanding Questions
You (and others interested in the Part 90 narrowbanding mandate) might want to check out
the following links:
LMR Narrowbanding information (a Yahoo! group) http://groups.yahoo.com/group/LMR_Narrowbanding
and
http://www.qualitymobile.com/NarrowbandReady.htm
http://www.qualitymobile.com/Part90NBNav.htm
BTW - the official date for Part 90 narrowbanding compliance is 2013
NR
Hi folks -
