I am trying to set up my APX mobile to monitor only to P25 Phase 2 system locally here in my county. I'm on the newer side of this and was hoping someone could help me out.
Couldnt really fully understand this forum as well as he doesnt actually say how to do it. Just that it can be done.![]()
XTS-5000 trunking scanner
Hi I’m trying to program my Motorola XTS 5000 to be a trunking scanner when I go into Trunking system in the Astro 25 cps it won’t let me select Astro 25 it only comes up with II ?forums.radioreference.com
You aren’t going to find many people on this site who are going to help you put an unauthorized radio on a public safety system.Couldnt really fully understand this forum as well as he doesnt actually say how to do it. Just that it can be done.
"DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO FOR NAS, NO."I've reached the point where I will no longer offer any advice to assist anyone in applying the NAS method with any radio.
All of this is valid for MSI subscribers, but other vendors software has been compromised/modified to not require such keys. Then you have Relm who is the ONLY P25 subscriber vendor who's software, known as Radio Editing Software (RES) can be purchased legally by and end user and allows for a true RECEIVE ONLY P25 trunking system with talk groups and scan lists to be added to the radio, system ID fields become greyed out as does the RID. Radio is a true RX ONLY unit and will in NO WAY emit ANYTHING RF at that point.The issue here is there is no "legitimate" way to NAS any P25 Trunking system, especially a Phase 2 one! What it comes down to is SECURITY and LEGALITY. Even if you knew enough to safely set up each scan list, zone, all your Personalities properly, AND made sure in the Trunking Personality that Transmit Mode is set to TG/AG Disabled, you still need a System Key in order to add TG's and other info. If you need to NAS that means you don't have a legit Sys Key, which makes it illegal no matter how you slice it. And just because you don't see your radio busy flashing red attempting to affiliate, doesn't mean it won't affiliate in the background. Your radio doesn't tell you every time it attempts to speak to the Controller. I am not being the NAS Police here, but I AM a MSI contracted employee and I have seen what happens to people that are caught with rogue radios on a system; depending where you live can either range from confiscating your radio, to a hefty fine, to jail time, or a combination of all 3. Make sure you know what you're doing or just don't do it...
This should be clarified, it does come up of occasionally. some new NAS users will think this is a secret special setting that will prevent transmit disable for that allows being on a trunked talkgroup, it is not. While it will prevent a PTT on a talkgroup as its ability to disable a subscriber to make a voice call on a talkgroup. The feature will still allow a register/affiliate if a trunked talkgroup is selectedAND made sure in the Trunking Personality that Transmit Mode is set to TG/AG Disabled
I've never spent over $40 to NAS, yet. (As of right now) I don't need an APX to listen to my local P25, when a clapped out XTL5000 with a W4 works "Just Fine®". Some peoples fascination with drawing attention to what's on their hip or velcro'd to their dash, will never cease to amaze me.When you get to the point of having to spend $600 or so on a radio to NAS with,
I've reached the point where I will no longer offer any advice to assist anyone in applying the NAS method with any radio. I won't have any part of even any incidental liability or blame.
