NAS Programming
tsalmrsystemtech
I was wondering if there is a dec or hex you can use on a channel that will open up every talkgroup so you can scan a whole site.
I know like on my unication it is 65535 dec and FFFF hex. This will allow all talkgroups to open up.
Just curious.
chrismol1
P25 TruCking!
I've tried many different hex addresses, no the Motorola CPS will not. Supposedly there is ATG that will but it will have to affiliate, so no go for NAS. You can scan voice channels CSQ or with talkgroup 65535 selective call ignoring encrpty) but it really doesn't work as well as the control channel immediately for switching to the voice channel and often cuts off transmissions. Tho with a modern APX you can forget the old 15+1 limited tg limitation
GTR8000
NY/NJ Database Guy
BEE00
That is a function of the system, not the subscriber. If the feature is not provisioned on the system, it doesn't matter what the codeplug has programmed into it...affiliated or otherwise.
GTR8000
NY/NJ Database Guy
BEE00
I should also add that ATG (Announcement Talk Group) is not a "catch all" wildcard, even if it is provisioned in the system. It's essentially an "All Call" that is only used in particular instances where transmissions need to go out on all talkgroups (or groups of talkgroups) at the same time.
Bottom line is that there is no way possible to have a Motorola subscriber open up for any and all talkgroups using some sort of wildcard. The closet thing you could achieve is with P25 conventional using the F7E NAC, which is the P25 equivalent of CSQ.
