Nashua Rebanding Roll Call
wb2bon
Merrimack, NH
Could we get reports from people who have their scanners fully operational on the rebanded Nashua system. Be specific with Make, Model, Firmware, Software, any special hints, problems you encountered, etc.
Also reports from those who still need help. Again, be specific with Make, Model, Firmware, Software, etc. and exact problems you are experencing.
Maybe we can match up those who have with those who haven't.
Thanks,
Manny
wb2bon
firenutts
Hudson NH
396 & 296
this worked for my 396 but not for my 296
I changed my nashua system to a Motorola Custom system with the new frequencies, used the band plans below.
bandplan
1- 851.0125 - 854.0 offset 0 spacing 25KHz
2- 851.025 - 854.0 offset 440 spacing 25KHZ
The 296 picks up a couple of the DPW talkgroups and it locks up on it. I doesnot pick up the fire/ems/police groups. If anyone has info for the 296 I would appreciate it.
wb2bon
Merrimack, NH
BC296 link info
Uniden Links:
ScannerManuals < UnidenMan4 < TWiki
BC296DFirmwareUpdate < UnidenMan4 < TWiki
Also, the tables you listed don't appear to be correct. This should work, per link above.
Band Plan Base Freq (Lower) Base Freq (Upper) Offset Polarity Spacing
1 851.0250MHz 854.0000MHz 440 + 25 kHz
2 851.0125MHz 868.9875MHz 0 + 25 kHz
My Scanner:
Scanner: Uniden BC796D
Firmware: 3.60
Software: Uniden's included / Proscan 1.8.3 - Neither handles rebanding.
Control channel: 853.2625 mHz.
Instructions: BC796DFirmwareUpdate < UnidenMan4 < TWiki
Some postings have differing trunking tables. The ones in the above link is correct.
Entered tables manually. The old software was used for the talk-groups and frequencies.
Some growing pains, but appears working ok.
Manny
wb2bon
NYRHKY94
Brunswick County, NC
Successfully Rebanded the Following Scanners for Nashua:
1) Pro-96 & Pro-2096
v1.4 Firmware
Installed Win96 v1.59
Went to Nashua Bank in my P96 File
Selected multi-table under MOT 3600 CC
Clicked on Extended Tables Button
Selected 800 MHZ Rebanded
Saved & Uploaded the P96 File
2) Uniden BCD996T
v3.0.2 Update
Hand configured the 2 Custom Band Plans noted on the bottom of
Uniden's instructions for the v3.0.2 update
3) PSR-600
v1.6 Firmware
Installed Win500 v1.80
Went to Nashua system in my Win500 File
Selected custom under the trunking tables drop down menu
Put rebanded control channels in system frequencies tab
Clicked on trunking tables button and selected 800 MHZ rebanded
Saved & Uploaded the Win500 File
4) Pro-106
v1.6 Firmware
Thanks - Mike
wb2bon
Merrimack, NH
Bc796d
Firmware: 3.60
Instructions:
http://info.uniden.com/twiki/bin/view/UnidenMan4/BC796DFirmwareUpdate
Some postings have incorrect trunking tables. See message 396 & 296 above.
The ones in the above link are correct. Entered tables manually.
Manny
wb2bon
wb2bon
Merrimack, NH
Dave, K1DAS is correct
Sorry for the typo.
"mHz" is a Millihertz, or a thousandth of a hertz (sure wish we has cycles back).
"MHz" is a Megahertz, or a million hertz.
Manny
wb2bon
n1das
Nashua, NH
What?? 853.2625mhz = 853262500.0 Hz
m = milli = 0.001
M = Mega, i.e., million = 1,000,000
1 mHz = 1 milliHertz = 0.001 Hz
1 MHz = 1 MegaHertz = 1,000,000 Hz
I've rebanding my RadioShack PRO-96 successfully using Win96.
I need to get a new cable to work on my Uniden 396T.
Sinister
New Hampshire
Rebanded Nashua with success using Win500
Pro-197
v1.6 Firmware
software Win500 v1.80
Put Nashua rebanded frequencies in Win500 by selecting system frequencies tab
