National/State emergencies.
howie38
Pemberton NJ
In this environment of political unrest leading up to the inauguration and beyond, what would be good to have loaded into my scanner?
WB9YBM
At least personally, I'd probably put priority on having enough essentials (food, water, etc.)...
@howie38 Here are a few suggestions, depending where you are located, or at least a place to start.
* New Jersey Interoperability Communications System (NJICS) New Jersey Interoperability Communications System (NJICS) Trunking System, Statewide, Multi-State - Scanner Frequencies
** NJ Army National Guard Talkgroups
** NJ Task Force 1 Talkgroups
** Interagency & Mutual-Aid Talkgroups
* National Interoperability National Interoperability Scanner Frequencies and Radio Frequency Reference
* NJ Common/Shared New Jersey - NJ Common/Shared Scanner Frequencies and Radio Frequency Reference
Skypilot007
Medford, NJ
Don't forget the ammo!
Everything N1GAW mentioned is spot on, add the NJSP system also if you don't have it.
I also like to monitor air traffic and base activities at Joint Base McGuire. If things get busy there you know something is up.
Burlington County - McGuire Air Force Base (WRI) Scanner Frequencies and Radio Frequency Reference
United States Air Force (57C) Trunking System, Multiple, Multi-State - Scanner Frequencies
For entertainment you could listen to the Hammies try to save the world on the ARES RACES nets! Stay safe.
ecps92
Taxachusetts
Main Radio with the normal monitoring
Secondary radio in SEARCH mode to find New or little used channels.
3rd, 4th if you have them searching different bands [ VHF, UHF, T-Band, 700, 800, NIFOG Interops, Local Interops ]
