NC MilCom NOTAM listed freqs
spacellamaman
Due to what is likely the permanent loss of Milradiocomms.com, and the lack of movement on this site to implement something similar, see: (2) Mil Air submissions, like milaircomms.com | RadioReference.com Forums
If no one objects, I think it could be helpful to list NC related NOTAMs that give a frequency, as that is about as solid a lead as one can get. I'll start with one listed today:
40.775 FM
KFBG SIMMONS AAF
M0463/22 - SOUTHEAST RAMP 82ND CAB IS CONDUCTING FARP OPERATIONS (PEGASUS
FARP) DURING THE HOURS OF 1800-0400Z (1400-0001L) MONDAY THRU
THURSDAY. OPERATIONAL FREQUENCY IS FM 40.775. PEGASUS FARP IS
AVAILABLE TO ALL 82CAB ASSETS. 15 AUG 21:52 2022 UNTIL 01 SEP 04:01 2022. CREATED:
15 AUG 21:52 2022
spacellamaman
this one pops up from time to time and is a good example of why I find these to be useful beyond the scope of the NOTAM
M0599/22 - AERODROME FLIGHT STRIP 2 (PU895947) 3RD BN 58TH AVN REG WILL SET
UP EQUIPMENT AND PROVIDE AIR TRAFFIC SERVICES FOR AIRCRAFT
OPERATING IN THE VICINITY OF FLIGHT STRIP 2. THE FLIGHT STRIP IS
OPEN TO ALL ROTARY WING AIRCRAFT. SERVICES WILL BE PROVIDED FROM
0900(L) TO 1600(L) ON 17, 19, AND 21 OCT. OPERATIONAL FREQUENCIES
ARE 341.675 (UHF) , 141.050 (VHF) AND 69.875 (FM). 17 OCT 13:00 2022 UNTIL
21 OCT 20:00 2022. CREATED: 14 OCT 21:49 2022
Both 141.050 (VHF) AND 69.875 (FM) I have encountered in use in the KVUJ/Uwharrie region. 69.875 used by helos once or twice and 141.050 was used for A2G and A2A in an unusual exercise around Badin lake a couple of years ago.
I suspect freqs that pop up in NOTAMs in this manner are probably presets for various units.
spacellamaman
A NEW ONE! Well I can't recall seeing or hearing it active before:
30.050 FM -82nd CAB FARP
KFBG SIMMONS AAF
M0196/23 - SOUTHEAST RAMP THERE WILL BE FARP OPERATIONS AVAILABLE TO ALL
82ND CAB AVIATION ASSETS. PILOTS ENTERING THE FARP AREA ARE TO
EXERCISE CAUTION DUE TO AN INCREASE IN PERSONNEL AND EQUIPMENT IN
THE AREA. COMMUNICATIONS FOR THE FARP ARE AVAILABLE ON FM 30.050. 07 MAR 05:01
2023 UNTIL 13 MAR 03:59 2023. CREATED: 06 MAR 23:55 2023
spacellamaman
41.425 FM
KFBG SIMMONS AAF
M0585/23 - AERODROME - SOUTHEAST RAMP – THERE WILL BE A TWO POINT FARP
OPERATIONS ON SAAF SE RAMP FOR TRAINING. FUEL WILL BE AVAILABLE TO
ALL AIRCRAFT AND ALL 82ND CAB AVIATION ASSETS. PILOTS ENTERING THE
FARP AREA ARE TO EXERCISE CAUTION DUE TO AN INCREASE IN PERSONNEL
AND EQUIPMENT IN THE AREA. COMMUNICATIONS FOR THE FARP ARE
AVAILABLE ON FM 41.425. FOR MORE INFORMATION YOU MAY CONTACT SAAF
BASEOPS AT 910-396-7804/1824. 19 AUG 21:00 2023 UNTIL 20 AUG 09:00 2023. CREATED:
16 AUG 16:41 2023
As a side note, I have seen the .425 pop up alot with similar activities/units ie: 141.425, 273.425 that sort of thing.
Whops and another
255.4
KGSO PIEDMONT TRIAD INTL
08/054 - COM REMOTE COM OUTLET 255.4 U/S. 23 AUG 04:00 2023 UNTIL 23 AUG 10:00 2023. CREATED:
19 AUG 05:09 2023
