NCPD 3+6 Repeater Issues?
bezking
On the Road
Hi all,
I was listening to 478.1925 this morning and it sounded like something was up with the repeater... It seemed to be randomly transmitting what sounded like a courtesy tone, even if somebody was transmitting. Anybody else hearing this?
Thunderknight
Bletchley Park
Hi all,
Not familiar with that agency...but some agencies have their repeaters send a fixed-interval (not random) tone that is sent when the commercial power at the repeater site is out.
I think in some jurisdications out west they have something they call the "beeper" that does something similar to indicate the channel has radio silence in effect.
bezking
On the Road
Could be the first one, but I've never heard it before, and can't be the second one because people just kept talking. Interesting.
w2lie
New York DB Admin
Long Island, NY
LIBNS is located 12.5khz to the south of NCPD 3/6's frequency.
It is them you are hearing...
If I use a radio with out PL tones, LIBNS will actually mute out NCPD 3/6 from my radio, and I will hear them instead.
bezking
On the Road
Wow... Does this interfere with the PD comms? (on their side, not ours)
Thats interesting because I have never heard any knid of interference on 3+6... Hmmm.
FireMarshalRob
Ok, So the proper answer to your question is diagnostic tones. You are either listening to an MSF5000 or Quantar repeater that is transmitting some sort of a trouble code. This will occur when someone is talking or not talking, and usually indicates a problem with an antenna line (High SWR), reduced power condition, loss of ac, pa failure etc.
P.S. NCPD fleet of radios is so old, beat up and off channel, that half of the mobiles can be heard 3khz up or down from their operating freq.
bezking
On the Road
Ah. I see. Thanks Rob - In fact I accidentally plugged in the incorrect frequency into the radio and heard half of the NCPD channel - it was only some of the units, not all...
scosgt
The problem with the system is that they have to run absurd power to enable the system to work in most areas of the actual coverage area. Most of my radios pick up the 4th and 5th on the 3&6 freq, as well as on aviation. This is because the repeater in Elmont is so strong. The 4th precinct is notorious for dead spots in the Five Towns.
So in many areas you may be hearing splash from 477.2125
You will not hear the mobiles on their transmit freq. That is low power. You are hearing the repeater.
