ind224
161.340 Avon Big Four
Is this the new digital? Noticed it last night. Nasty chirp burst squeal sound.
The county agency I retired from a couple of years ago was (and still is) an all VHF radio system. Several years ago Motorola stopped supporting their VHF radios so the county had to seek other suppliers for their VHF radios. They are now using Kenwood and Icom commercial radios. As far as I know, these radios are not digital capable. The radios the railroads are going to have the capability of being switched to the NXDN protocols if they make the switch.
IDAS is NXDN. They're not "basically the same thing", IDAS uses the NXDN digital protocol.Most modern icom or kenwood are digital compatible. Depending on model it can have a board installed to run nxdn/Idas or p25 format or some only will allow either the nxdn Idas format or p25 and won't allow for all 2/3. Basically majority are ready and can do one or either them formats. Idas and nxdn are basically same thing. I got a icom radio with the board pre installed so if any rail road went digital in a yard or road I'd have no problem monitoring. Do you recall your former agencies model of radio they replaced motorola depleted contract with?
Referring to the basic digital protocol. You get into trunking it won't work together. Since everyone want so be pin point accurate smart here.
