tradecraft6f
NEED OOB EDITOR for CPS TO GET 70CM,ETC ON MY XTS 5000 450-512 that i bought at a great deal...tried a posted Mega nz file but indicated that file wasnt available...ANY help and info greatly appreciated....THANKS!!
WELL THERE WAS A LINK THAT LED ME ORIGINALLY TO RR FOR THIS INFO!!
my experience with the Spectras, Maratracs and Maxtracs has been that more often than not, trying to push that far out of band results in unstable VCO lock, and even when it does, it's only after retuning if at all...
Just my £0.013...
Since it's an XTS, (along with the XTL) they are quite forgiving to the point you can't compare to the older lines. I have seen XTL's pushed down into the 432 range without problems, and the hammy bottom of 440 is easily obtained albeit at slightly less power output. A good alignment can fix that, if a slight power loss (5%ish) is actually important, which I cannot think of a reason it would be.
I'll give you $5 for it...WELL.Got the good deal xts 5000 from ebay today..turns out it had a previous set of type II smartzone departments on it with a Advanced SYSTEM KEY on it,IT would not allow rewriting the codeplug.the radio will only do SMARTZONE II and digital p25 450-512...i advised the seller that it was a piece of crap and got a refund on it,advised of the Advanced SYSTEM KEY ,>>"But I Removed The ASK From The Codeplug,Which IS Good"<< and its still a piece of crap with the Smartzone II and P25 450-512 ONLY FEATURE..
thats why its getting returned..its technically on a worthless band digitally
the ebay seller originally said i can send the radio back and he "knew"someone that could fix the ASK issue(remove it),but since the radio wont do conventional 450-512 then its worthless for gmrs/frs or much anything else..but im sending it back for refund got the return label last night..Dont need the drama crap..
