Need a bit of help with Oddcast
73cuda
Florida
Hey Guys,
I'm switching from Simplecast to oddcast and I almost have it. I've been following directions from http://www.w2lie.net/e107_plugins/content/content.php?content.17
I had Simplecast working perfect including alpha tags but cannot justify $140. to purchase it. So that's why I've switched.
Oddcast is working great with Icecast but my problem is the monitor program. To be specific, monitor is getting and "trying" to send the correct tags but after it says "sending title" '154.250' monitor displays 'HTTP/1.1 200 OK' not received
I've tried everything I can think of so far.
Any advice would be appreciated.
Thanks,
73
ICP963
Chandler, AZ
73cuda said:
I'm sorry, I missed this post somehow... http://www.radioreference.com/forums/showpost.php?p=629024&postcount=4
I un commented Icecast and commented out encoder in monitor.cfg. and now monitor sends directly to Icecast and it's working fine so far.
Now if I can figure out why the VU meters aren't working on Oddcast.
Thanks, maybe this post will help someone else,
73
Try relelecting your audio input on oddcast, that seems to do the trick here.
How are you getting your alpha tage? I find using ID Tracker and letting the stand alone Oddcast pick the info from ID Tracker's titlebar works great.
Check out http://stream.electropost.net:8000/icp963.ogg for a view of how mine looks.
