Need a COR
timkilbride
Linn Co Iowa
I'm looking for a carrier operated relay to use with a scanner to make a UHF 8 channel GM300 TX. A VOX system should work. I'm doing some experimenting getting WX alerts over UHF ham ect. . . Is there any kit out there I could build or something already made? I have looked at various sites but can't find anything that fit my needs.
TIA,
Tim K.
obijohn
TIA,
Tim K.
And this is legal, right? You need to do a reality check here. Short of ham radio, you are not going to be legal. You did consider this. Yes?
timkilbride
Linn Co Iowa
So you can't have weather warnings from the NWS send over UHF ham with proper indentification? I hear them all the time on VHF ham radio repeaters.
Tim K.
Grog
West of Charlotte NC
Tim K.
Don't take legal advice from a scanner forum, I've heard of those weather alerts as well. Just remember, the FCC issues the rules, not RR users :D
EDACSTECH
Ocean City,MD
TIA,
Tim K.
A CES RM20+ will work. I have used them for many applications and they work well.
http://www.ceswireless.com/downloads/man20_1.pdf
KC0QNB
Gothenburg, NE
I don't think a COR will do what you want, a carrier operated relay triggers when there is a carrier, and since weather radio stations are always transmitting, there is always a carrier.
A good weather radio or same decoder that recognizes the eom message and a store and forward recorder unit that can be programmed with your callsign to play at the after the NWR eom and a vox circuit might work better.
It sounds good anyway I am sure you can find the pieces. good luck
KC0QNB
Gothenburg, NE
OR you can get one of these
everything in one package for more flexibility and a built in receiver there is this one also
and there is a forum the WX200 also uses a windows interface, If I were doing what you want to do no point in "reinventing the wheel"
