Need a java file compiled
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
I have a file that is a .java file and I can't compile it in Windows 7 useing CMD and I bet it has something to do with path crap so I'm not messing with it. I looked online for a java compiler and found this. JXXX Compiler Service But the the resulting jar file won't run. Attached is the java file I need compiled. It's an XOR decryptor.
  • Encryption.zip
poltergeisty
Banned
I tried opening the class file with Java but all I get is a quick DOS prompt and then nothing. I don't know why the author just didn't compile the damn thing before posting it.
Anyone know of a program preferably with a GUI that can crack XOR? I looked and looked and found Python stuff and dos command stuff, b ut wasn't what I was looking for and this app in Java is more what I need. I'm just experimenting with XOR right now.
flythunderbird
Grid square EM99fh
Sounds like you might have a classpath problem, as you said. You might try going out to a DOS prompt and running the class file from the folder holding the file while using the -verbose flag, like this:
java -verbose Encryption
... and it will give you output. I get this when I run it:
poltergeisty
Banned
Yeah, I know there is a path issue and didn't want to mess around with paths.
Nope, won't open on the desktop either. Even tried opening with my browser. Just pulls up a DOS prompt and goes away.
