need a lil help maybe some one can help me here?
fireman846
indiana
ok first off im not repet not asking for software! i want to learn how to program my astro spectra and use it for rx'ing. i bought it to use for my fire dept but the switched to rebanding the next month before i can do anything. there are still somethings that are old school radio (non digital) what is the best way or where do i go any help please i really what to do this thanks
I take you are talking about a trucking system. In order to program it you will need a system key, valid radio ID for the trunking system and for rebanding the proper firmware and software that supports rebanding.
I wouldn't do this with a mobile. Too easy to select a trunking channel and affiliate with the system. If you do affiliate with the system and you don't have a proper radio ID kiss your radio good bye and say hi to your new paper weight.
In other words get a scanner.
fireman846
indiana
lol wow ok i have a scanner and looking at a new one i was just wanting to give this a try. reband on this radio is not nessasary. we do still have some conventional radios around that i was looking at trying. all that info radio keys and and stuff if some one could tell me what i need to do to find that ill take a risk to try i know i need to go to the big M to get software but everything else is what i want to know
N4DES
Retired 0598 Czar ÆS Ø
South FL
Contact your system administrator....if your a novice at this, which it seems that you are, you can severly affect the operation of the system or might end up with a brick when it gets inhibitied.
Here is another bit of advice, go get a second scanner.
n5ims
First and formost, talk to the radio system administor for the system you need programmed. Chances are fair that they already have the software, etc. to program your radio. You'll need to get their permission no matter what anyway, so you might as well do it right from the start. If they say yes, they'll probably take care of things right. If they say no, accept their "No" and just sell the radio on e-bay and use a scanner.
The advantages doing this are huge. First, you'll be an authorized user (assuming they say yes) and as legal as you can get. You will also have assurance that the radio is programmed correctly and if not, they'll know it wasn't your fault and help correct things for you.
If you do it yourself (especially if they say no), you'll be in big trouble and at the least have a good chance of getting your radio "bricked" so even selling it on e-bay is out. You'll also have a good chance of being removed from the fire department as well as possible large fines from the FCC and legal problems with your local police. Neither organization take lightly the use of unauthorized transmissions on public safety frequencies.
See this thread for proof that the FCC does go after folks that program radios with the ability to transmit on frequencies they're not legally authorized to operate on (and this was due to an expired license that the radio shop didn't know had expired). http://forums.radioreference.com/industry-discussion/166582-fcc-wants-fine-radio-shop.html
