Need a little assistance
sws343
Chattanooga, TN
Needing a GRE.program for "Western Area Regional Radio System Authority". Does anybody have that they have already used in PSR-600? I have updated scanner but it still sounds garbled or pixalated when audio is heard 80% of the time. Carroll and Haralson County. Fire Dispatch in Carroll sounds good. Stan
N8IAA
Fortunately, GA
Try using the radio shack 800Mhz antenna. It will greatly increase your signal strength. Also, are you using the scanner with the squelch knob closed? You may want to open it all the way for improved signal. If you are using Win500, upload the system that way.
HTH,
Larry
terrister
Ga
Also, this system is not all the way ready for others yet. Still some issues to work out. More towers to build.
I listen on a pro 106 and use Win500 software.
