I am getting digital lpulsing sounds in the speakers! I got the Signal VCO set like this: Audio output- Speakers Digital Output - unspecified. Mute is unchecked. (all I did was reboot the PC)
If I check Mute then I get digital sounds when a talkgroup comes up on the Unitrunker site screen.
No movement of the DSD scope line.
what's next?
Now that we have digital audio out the speakers, we need to reroute it through the virtual audio cable instead.
The signal receiver has no audio output whatsoever. Set both audio outputs to unspecified. The only role the signal receiver has is unitrunker watching the control channel and we do not need to hear that in any way at any time.
The voice receiver should be set to either receive analog voice or digital voice by the checkboxes. Accordingly, the audio should route either analog to speakers or digital to your virtual audio cable and the opposing side at to unspecified.
That will put the digital audio across the virtual audio cable.
If you have multiple cables running at a time, make sure they are set to the correct cables.
Check the volumes but input and output through Windows. Right click the sound icon in your system tray in the bottom right > recording devices / playback devices. You should see a green/grey bar bounce next to vertical volume sliders.
These volumes will probably not need to be 100% but first get volume them tweak to get the error count down in dsdplus.
Again, double check the input and output numbers on dsdplus haven't changed since reboot and you're still getting digital audio from virtual audio and outputting to the speakers.
If this is working correctly, you should only hear digitized voice, no digital pulses like you have been.
If someone is streaming the system you're trying to listen to, you can try comparing what you hear vs the stream. There will be less compression (it should sound better on your end) and you will hear everything about 30-60 seconds before the stream.
Let me know! Good night
Sent from my SM-G930W8 using Tapatalk
