My belt clip broke so I need a new one. Preferably on Amazon if possible.
This is interesting because the belt clip on the 396 is a different belt clip than on the 436. But this Uniden site says it works on both of the radios. The belt clips for the 436 is a little bit longer from what I remember. I know that the 396 belt clip will of course fit on it but it's not as tight. I tried using a brand new 396 belt clip on my 436 but it would not work or keep the radio from still wanting to spin. I didn't even realize they were different until a friend told me and then I looked closer at them and saw the differences.$7.50 from Uniden
https://www.uniden.com/shop/communication/belt-clip-5/
Sent from my SAMSUNG-SM-G930A using Tapatalk
I replied to it.Check your private messages.
So you just lost the screw in yours? I had to torque mine with a screw driver to keep it tight.The screw that holds the button on pulled out while clipping to my belt? Seriously?
Ouch!! Why uniden stuck with that design I'll never know.Screw came out with plastic on the threads of it....
Can you post a pic of what the Bcd396T clip looks like?Mine broke too, after only a few weeks of use - the latching part snapped off. My SDS100 almost met its demise that day - I did the hot-potato-dance, and somehow managed to keep it from smashing itself on the concrete floor in the garage. I'm now using the clip that came with my BCD396T, which has lasted close to 15 years without this happening. Seems like the plastic used for the SDS100 is more shiny/hard/brittle. Maybe if enough people complain about this, Uniden will come up with a better version....
maybe a bigger screw of same length with corse thread...Mine broke too, after only a few weeks of use - the latching part snapped off. My SDS100 almost met its demise that day - I did the hot-potato-dance, and somehow managed to keep it from smashing itself on the concrete floor in the garage. I'm now using the clip that came with my BCD396T, which has lasted close to 15 years without this happening. Seems like the plastic used for the SDS100 is more shiny/hard/brittle. Maybe if enough people complain about this, Uniden will come up with a better version....
There must be two different parts in use then. Mine says UT-865A, with 59451G2-H underneath.Just an FYI, the belt clip for the SDS100 is exactly the same as the one for the BCD436HP. The part numbers from the clips (inside, on one of the pieces) is: UT-607Z, with C2690G1 underneath.
