Problem with a true P25 digital trunked system is that there is no way to program the
radio for receive only. The way the system software is and how the trunking system
for it works, the radio "HAS TO AFFILIATE" on the system in order for it to function.
If you wanted to put the radio onto a non P25 trunking system, then that is a different
story. There are a couple of ways to set the radio up so that it won't affiliate.
However, it still can TX if the system sends the proper command to request all
radios on the system to affiliate. Many systems do this just to find radios that
have been placed there without permission. In this case, unless you disconnected
the exciter and removed the power from the PA, the radio could TX.
You would be better off just obtaining a scanner that can work on the P25 system.
When I say the P25 system, I am talking about the control channel data rate. On
an analog trunking system, the control channel data rate is 3600. You can have
an older digital trunking system that still uses the 3600 data rate. However, on
a true P25 digital trunking system, the control channel data rate will be 9600.
You can hear the higher data rate by just using a scanner.
Jim
southhaysfireman said:
I have a Motorola Spectra Digital radio with the a7 control head. I would like to program this radio system into the radio for receive only.
http://www.radioreference.com/apps/db/?sid=2
the guy at the radio shop I called said I need a system code or a system key or something like that to do it. Has anyone ever heard of this?
