Anything less than LMR, and you will lose the gain you get by using a yagi.
wildbillx said:what would be an ok mast mount amp. I have only seen them over $150. Where can I get one.
zguy1243 said:75 feet of Rg8 at 800Mhz frequencies will be a disaster...
zz0468 said:Hardly a disaster...
At 850 MHz, LMR400 shows a loss of 2.8 db for 75', and RG8 is 5 db for 75'. So, the difference in loss between RG8 and LMR400 in that installation would be around 2.2 db - certainly not optimal, but I'd hardly call it a disaster. Get the best you can afford, and is available to you. RG6, btw, is 6.7 db for 75', a difference of almot 4 db.
zz0468 said:I also wouldn't use a cable tv amp. If it's not designed for weak signal, low noise operation, it may appear to make signals stronger, but it could also be adding more noise than signal, and actually reducing the receiver's ability to detect a weak signal.
zz0468 said:That Commscope loss specification is meaningless without referencing a frequency. Is that 5.5 db/100' at 850 mhz?
Let's put something into a better perspective... 2 db sounds like a lot, and when you're losing watts in a transmitter line, it can amount to a lot of power. But let's look at the typical scanner receiver with .25 microvolt sensitivity. That 2 db is the difference between .25 and .31 microvolts. You could measure the difference, but in practice, you'd probably barely notice it if you were trying.
Dubbin said:Well it was a disaster for me. I switched from RG8 to RG11 (around 60ft) and since then I am picking up 800mhz systems that I never even came close to picking up with the RG8 (even with an amp).
zguy1243 said:Yeah RG11 is great stuff man, For the money you cant beat it. For runs up to 75 feet i would not hesitate to use RG11, I love it.
zz0468 said:That's quite a dramatic change for cables that only have 1.1 db difference in loss (for 60 feet). I'd seriously suspect that some other factors are involved besides just specified cable loss. Perhaps the RG8 run was just plain bad, or a connector was improperly installed. Fact is, the cable specs show RG11 is 2 db better per 100' at 800 MHz than RG8 is. That 2 db would quiet a slightly noisy signal just a bit. But it's simply not enough to account for bringing something from being completely unreadable to usable. Remember, a 1 db change is barely detectable by the human ear if you're looking for it. 2 db isn't much more detectable than that. 3 db is easily discerned, but it is not a dramatic change, especially for quieting fm signals. A 3 db improvement would bring something from the threshold of being detectable, to an annoyingly noisy signal that you don't want to stop to listen to.
Now... having said all that, if you chase after a db or two in your coax, select an antenna that has a couple of db gain in the directions you need it, and don't throw it all away by running it through a noisy distribution amp for the sake of higher s meter readings, all those minor improvements will actually add up to something that you can really notice.
reference: Belden 8237 RG8 vs Belden 8213 RG11.
http://www.ocarc.ca/coax.htm
Dubbin said:Nope nothing was wrong with the coax or any of the connections. At first I was thinking that same thing so I replaced it all but it made no difference. BTW it was RG8X that I replaced with the solid center RG11. I think you will find a bigger difference between the two.
