Yes I have that BUT it only gives the Latest update to 1.10.02 In which i read out here it cuts P25 reception it has a bug
Then, run the utility and follow the on-screen prompts to select the scanner model and firmware version to apply.
HI Ron I just bought this BCD 996P2 for someone on E-bay and want to firmware update it to 1.09.12Why do you need the older version? Normally when people in the past on these forums ask, the thinking is something was broken on the newer firmware and they think thats the issue when the issue is programming or simulcast.
996P2 firmware has been out for a couple years - also hasn't been updated since, but people aren't reporting issues.
Uniden outside of at least the T models and before never released a stand alone downloadable firmware for the P2. So what your asking is not doable outside of Uniden themselves that have it.
If you look through the rest of the thread, you will see that the issue the user had was caused by a programming error.I dont want the LATEST version BECAUSE someone on the forum SAID that it CUT out his P25 reception
all of it.
YES IT' A BCD radio NOT ubcYou probably should not be using any firmware from that page. They were meant for the BCD996P2 (U.S. version), which is not the same as your UBC996P2.
That page also contains a warning even with the proper radio, BCD996P2:
Please check your scanner's serial number before updating.
If your scanner's serial number starts with 378A, be sure to use ONLY this (or newer) version. The scanner will stop working using earlier versions.
If your scanner's serial number starts with 378Z, you can update to this (or newer) versions (again for the BCD, not the UBC models)
There may be a misunderstanding. There was a hardware change in later BCD996P2's which resulted in not being able to decode P25 frequencies above 171.2 MHz in the VHF high band. A firmware update was issued to fix the problem.Yes I have that BUT it only gives the Latest update to 1.10.02 In which i read out here it cuts P25 reception it has a bug
Here are the release notes for firmware version 1.10.02:There may be a misunderstanding. There was a hardware change in later BCD996P2's which resulted in not being able to decode P25 frequencies above 171.2 MHz in the VHF high band. A firmware update was issued to fix the problem.
So in other words, it would have been the update prior to 1.10.02 that created the problem as 1.10.02 is the one that fixed it.
