need antenna advice
chaddo
have a little cobra from radio shack 4 watt, want to install some antennas on gravel truck what should i go with for best disance.
freqs
warren michigan
I have used K40 and Wilson I like wilson better but both do well .i drive Roll Off trucks and we use CB alot in them and only use Magmount do to I can take the whole system out at night and take home with me .Sometimes things walk at night .One thing are you looking for a mamount antenna or are you going to do mirror mount ? if you do miror mount ther are tons of potions in those over magmount .
chaddo
antenna
well i have the mirror mounts there but im unsure if all hooked up or if i should just get grab a mag mount. are there some good mag mounts that are like 4 feet dont want some huge big thing. i had two normal whips and wasntgetting hardly anywhere ,whips may have been junk though ,outside plastic was cracked ,could see the wire . im new and just trying to get into this
freqs
warren michigan
Take a look at H&Y Electronics they have tons of CB stuff a lil wilson is a good smaller mag mount antenna gets out good and its around $30 Stick with a name brand
