delta_p
- Joined
- Dec 24, 2007
- Messages
- 135
I am modifying my attic setup to place rotor on a mast with my Wilson 800Mhz yagi. I am thinking about adding an additional antenna for 2m (not necessarily directional if something decent is available). There are a few 2m and 70cm repeaters I like to pick up during incoming weather because of all the spotting reports. Some repeaters are local and the Wilson picks up ok, but some in neighboring county which even my Scantenna has trouble recieving. Can someone recommend some antenna that might work in this attic environment. The only thing I have looked over is the Cushcraft A2706S and the Diamond A144S5, both directional. Also, for a directional on the same mast as the 800Mhz is there any particular antenna separation to limiting interference between the two antenna. Thanks for any input.
PP
PP
