need better antenna
bmasters
miami county
I need to know that the best antenna is fo a 796d. i live in peru IN i pick up peru with 5 bars cass county with 1 bar wabash never, fulton county never , and howard county never on 800 mhz digital or howard county on edacs i have a huslter mounted 20 feet up. the stock antenna works better then the outside antenna any help would be appreciative
retroactiv
Chesterfield, IN USA
what type of wire do you have coming from your antenna, also have you tryed moving it in a different direction, you just never know... Also what is around your house possibly blocking it... There are a million different things.
delallen
Greenwood, IN
I have a bc296d on a omnidirectional that I can get 20-30 miles on- Then I have a bc796d that I have a yagi (directional) on it. I can receive the northern Monroe co. tower from Greenwood with 4 bars. With the yagi I can get all my local towers, but i can punch to the southwest to get the distant signals. The yagi made me smile for the dstance. Mine are mounted 20 feet up. These observations are on the Safe-T system. On vhf I get all of central Indiana on the omni directional.
I do use LMR400 coaxial cable. Everyone will have thier own favorite set-up that works best for them. I just did alot of reading. The antenna forum on this site has alot of good info.
I got the yagi from Scanner Master for around $180 as I recall.
Hope this helps you!
bmasters
miami county
I have a hustler dcl mounted 20 feet up with belden rg-8x i live in peru in a valley so nothing might not help i dont want to waste any money if nothing will work. i have asked on the antenna form gave me advice but try the indiana form to see if anybody live around that may had the same problem thanks
