need "Easier to Read" SDS100 / SDS200
llwade
Chillicothe Illinois
sure would be appreciated if Mark Lauretta would do a "Easier to Read" Digital Scanner & Sentinel Manual for the SDS100 / SDS200 scanners.
I am currently using the 436/536 edition but have ran into a few exceptions. Easier to Read is like a scanner "Bible". thank you for your time
sparklehorse
Portland, Oregon
The only differences I'm aware of (vs. the x36 models) are the filters and the display settings. Oh and the Ethernet stuff. Other than those items the programming is virtually identical. There may be some esoteric stuff under the hood I'm not aware of, but those are the main differences. So Marks Easier to Read x36 should get you through 98% of what you need to know.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
There are only a few slight differences between the 536 and the sdsxxx, mostly like someone else added, the display color grid and the new filters. Other than that they are virtually identical. I made a master profile in Sentinel for the 536. When I got the sds100 I simply wrote the same profile to the 100 (renamed it) and did the same with the sds200. All FLs, protocols, menu options, and preferences are the same. The SDS scanners were so simple to program, I basically transferred the settings of my 536 over to them and had them up and running in 5 minutes.
JD
kf4anc
