Need G5 Vehicle Bluetooth Solution (FCA)
Robotech2112
Carbon Unit.
Lenawee/ Monroe Line, Michigan
I have a 2016 Dodge Charger utilizing U Connect (Fiat Chrysler) infotainment system. It's Bluetooth is how I've connected my phones, and I've never had an issue connecting any Bluetooth enabled device... till now.
The G5 sees U Connect, the U Connect sees the G5. They pair. G5 internal speaker disables, BUT audio does not come through the vehicles system.
I have triple checked all my settings, and am at a loss. Are they not compatible? I need amplified volume for the G5 at highway speeds.
Any thoughts?
mattmac553
I have a 2018 Dodge Challenger, and my car treats each transmission I receive as a phone call that only last a fraction of a second.
N6ML
No, (I believe) he's saying that each transmission is like a separate phone-call. If it's a conversation (e.g. between dispatch and a mobile unit), it can be a lot of very short "phone-calls".
The next version of the firmware doesn't do that... but I've not had any luck getting the beta builds to talk to either of the head-units that I've tried so-far. It does work better with some other BlueTooth receivers, though.
mattmac553
I tried to replicate it now, but I can not even get it to connect. It just says that the pairing failed.
Robotech2112
Carbon Unit.
I purchased a small bluetooth receiver on Amazon. It plugs into my "Aux in"
on the car. If it works out, Ill post the particulars.
UPDATE... This Mpow BH129 has low fidelity and low audio output. With bluetooth volume on full and G5 volume on full, audio is "barely" loud enough for highway speeds. Everytime a transmission comes through an irritating announcement tone precedes it. Cheap rubbish.
I plugged it into a Motorola external speaker as well... even worse without amplification. :poop:
We need an emoji of a garbage can on here as well...lol.
etihparg
Gilbert, Arizona
I have just been successful connecting my G4 to an Android head unit. What I had to do is turn off and delete all other BT connections, including the OBDII transmitter. Then I turned on BT on the pager at there it was. Then I re-connected the other devises and they all work. Seem like it the page sees ANYTHING else it gets "confused". Hope this helps, all devices are different.
Robotech2112
Carbon Unit.
Thank you for that info.
