Need guidance for programming 6550 and 7550e on DMR with CPS2
kayn1n32008
ØÆSØ
Sector 001
Maybe each zone should really be a state, all repeaters in one state in one zone? What say you?
I would strongly recommend keeping your zones to 24 channels or less, most of my zones are 16ch or less. Spinning the dial gets old FAST.
For my analogue simplex zone, I actually broke it up into 2 zones, 146MHz and 147MHz. I also have a zone of 16 simplex DMR channels.
Keep in mind, your scan lists are 15 channels plus your selected channel.
wb4sqi
Cincinnati, OH
OK, I like this idea better than one zone per state as I originally planned. Keeps the channel count down to manageable levels. (<30)
Thank you both for your help.
kayn1n32008
ØÆSØ
Sector 001
No problem. You have LOTS of zones. Like I said, I'm at 34 for my XPR5550. Keeping them small makes it much easier to find the channel you want. Also keep in mind, that the radio will display the zones in alphabetical order, regardless of the order in CPS. I added a number at the beginning to be able to have the zones in the order I wanted them in the radio.
wb4sqi
Cincinnati, OH
Help!, Finally got some free time to begin adding additional repeaters but I'm stuck. The original CP had Zone 3 as "channel Pool" with one simplex frequency. I have been able to add four talk groups to this zone for a local Northern KY repeater but can't find a means of editing the zone name nor adding additional zones. One 1 is my hotspot and zone 2 is the local K8BIG repeater.
wb4sqi
Cincinnati, OH
OK, the blind hog finally found the acorn. I figured how to add zones now so all I need is to edit the name of zone 3 "channel pool"
wb4sqi
Cincinnati, OH
Thanks to all. Finally figured I could keep pushing channel pool down the list and adding zones above it. There's one frequency in that "zone" that can't be deleted so will just leave it alone. Now that I've got the zones created just need to populate each one with frequencies and talk groups.
Happy New Year to all and thank you so much for your help.
jaspence
Michigan
I have both ham and commercial radios, and FPP on the amateur units can be very useful in situations where only a couple of changes or additions need to be made. Take a look at the RFinder DMR for what is advertised as the easiest for adding contacts with no CPS needed.
wb4sqi
Cincinnati, OH
I did research the RFinder, read the QST review and queried google to read other reviews. Cost was a big turnoff to me. There is an identical unit (or units) available without the RFinder name at nearly half the price. I love the concept but that is 200% over the cost for my new Motorola 7550e. For me, I can learn CPS 2.0 and program my own handheld which has the best DMR audio of any radio I have had experience with and still have money in my wallet.
kayn1n32008
ØÆSØ
Sector 001
As I, and others have said, it doesn't show up in your radio when you push the code plug to it. Every item in the CP tree has a single default item in it. This is normal.
Happy New Year to you as well. Enjoy your new radio. I love my 7550.
