need help asap please
debcash
can someone please help me program my scanner. I just paid $15 and not even sure if i have to.
I have the wire going from scanner to computer & put in state and county and all it does is give me a giant list of numbers.
I thought the wire was supposed to be doing the down loading for me!?!?!?!??!?!
Please help me
northernsummit
Macedonia, Ohio
That list of the numbers are talk groups. You have to sit down and think about what you want to listen to.
Alternatively if you have a scanner that supports zip codes you can just put a zip code in. What area of Ohio are you hoping to listen in and what are you hoping to listen to?
16b
Central Ohio
To add to what others have already said, it’s important to know what kind of scanner you have because there are a lot of different models that all operate differently. Knowing what kind you have will give someone who knows that particular model a chance to provide better help.
Similarly, it’s helpful to know what you want to listen to as specifically as possible (e.g., xyz town police department) because someone familiar with the area can chime in with helpful information
debcash
Whistler WS 1040 It tells me that all i have to do is go to www.radioreference.com with the cord attached from scanner to computer. Then all instructions just stop. I did get on the website & access all the county police/fire/EMS but there is nothing after that, that im able to find as far as putting them on my scanner. I did enter some manually but it doesnt seem to be picking everything up. I would also like to hear weather alerts
debcash
I have no idea, thats my problem. I want to listen to police fire ems and weather alerts. But the instructions say plug in wire and go to the website im on.
fxdscon
¯\_(ツ)_/¯
What software are you using to access the database at Radio Reference to download frequencies? You haven't mentioned what programming software you're using, so if you don't know, you can't download from the database directly to your scanner without purchasing 3rd party software.
Check this link to see how the download programming works:
and check this link to see the necessary software that is compatible with your scanner:
N8IAA
Fortunately, GA
Please help me
No one can help unless you post State, County, city/cities, and the system/frequencies.
Help us to help you...............
debcash
Ohio-Brown-Mt.Orab but i have found a list of all the frequencies and have manually entered them. I have no T or G at on my screen while scanning if that matters
N8IAA
Fortunately, GA
You have to have software to import the info for your county into your scanner. Do you have software? If so, you sign in with your RR ID and password. Then you can import what you want into the scanner. Otherwise, programming by hand is going to take forever.
