ok heres what i got i have a uniden bearcat BCD996T scanner I have programmed the local area police and fire/ ems
heres my problem i have no idea how to set up the Illinois State Police i realize its a starcom21 i have no idea were to begin to get this setup
i need to know step by step (i have no cable so i have to do it manually by hand) how to program the State Police District 17 (LaSalle Bereau and Putnam Counties) in the scanner Headquarters is in LaSalle i need all the frequencies too
any and all help will be awesome
thanks
Obtain the control channels for the system you are interested in:
Motorola Trunked Radio System type II frequency entry
In this example we will enter this trunked radio site:
City of Salem "B" Tower Trunking System, Salem, Oregon - Scanner Frequencies
1. Press the menu button on the radio
2. Program System appears press the E/yes key.
3. Select New System Press E/yes key
4. Select System Type > MOT > press E/yes key > Confirm? > E/yes key
5. At the web site you get the control channels listed:
1. 856.48750a
2. 857.48750c
3. 858.48750a
6. Now you enter in one frequency at a time after making a site.
7. Turn the scroll knob to Edit Site > Press E/yes key
8. New Site Appears Press the E/yes key
9. Scroll to Set Frequencies > Press E/yes Key
10. New Frequency appears press E/yes key
11. Input Frequency 856.4875 > Press E/yes key
11a. If you were entering a EDACS or LTR trunked system you will be
prompted for the LCN Number, enter that number then press E/yes key
12. Turn the scroll knob to the "New Frequency" selection > Press E/yes
key
13. Enter Frequency 857.4875 > Press E/yes key
14. "New Frequency" is selected > Press E/yes key
15. Enter Frequency 858.4875 > Press E/yes key
You can now navigate around to check out the menus use the scroll knob.
1. to enter a selected item press the E/yes key
2. To go backwards while in a menu item press the menu button
When you are done press the L/O key. If you ever are lost in a menu or get
a yes/no question or want to get to the main radio scanner LCD screen
press the L/O key. It acts as an escape key does on your computer
keyboard.
At this point you can scan the system by pressing the scan key.
Using the Talk group ID list from radio reference you can cross reference
the active talk groups on the trunked system as you monitor it. If you are
interested in a talkgroup press the E/yes
Quick TGID Save?
If you don't want to hear a TGID "while it is active" double tap the L/O
key.
This is the simplest way to program the scanner without worry about
systems or groups. Your best bet is to try and use Freescan to program the
scanner using radio reference database for more advanced features.
You can obtain a USB-1 cable from Uniden Parts or Scanner Master.
