Baofeng Need help baofeng dm32
wsfn790
Friday at 9:27 PM
Hey there recently purchased a dm32 and I have problems receiving and transmitting on a repeater. I know i have pl tones and frequencies correct. It seems it is pinging the repeater. But no audio. It also doesn't seem like my transmissions are getting out. I can reach the repeater and recieve perfectly with my uv-5r. Ive tried manually programming and every setting i can think of on CPS. Anyone know why? Maybe faulty radio? Thanks so much!!
rescuecomm
Travelers Rest, SC
The DM-32UV software has the receive and transmit CTCSS positions reversed. The transmit PL is actually the receive and the receive PL is the transmit. Check the DM-32 on simplex with your UV5-R using the tones.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
Depending on your firmware version, some DM-32 models also require the Forbid Talkaround box in the channel detail screen to be checked in order for the repeater input frequency to work properly. This bug appears to have been fixed in later versions of the official Baofeng firmware.
devicelab
Radio N.E.R.D
WA (USA)
I believe this was fixed in the 1.41 CPS.
wsfn790
Requested replacement and it does the same thing. The radio acts like it isn't transmitting with enough power. I think im going to just send it back and buy something else. Ive done everything at this point.
BruceMichaels
Not "Some People"
Flying Over You
This may be an odd suggestion, as it happened to me, but have you made sure that either your volume is turned up and/or have you unplugged the programming cable from the radio (not from the computer but the radio itself).
wsfn790
Yeah this has been done and verified. It's been on 2 models now. I can hear the curchunck line in hitting the repeater but no audio. I've also verified this with a completely different verified radio on the same frequency and pl tones.
Are you using the supplied antenna? I've found that some aftermarket antennas don't make the SMA connection on the center pin.
I've tried the supplied antenna, a different radio model antenna, And a Nagoya 771 antenna. It will curchunk the repeater on both the dm32s I've tried and I can hear it on another functioning radio but the voice transmission will not go through on tx or rx, only the repeater curchunk.
