Need help copying a few O.C. channels ???
rbagley
Greanman
Oklahoma
Could use a little help with building a small system of channels. I want to copy some of the channels in the Orange Co. California fire dept. I'm trying to put together all the Tustin & Santa Ana fire dept channels into a small system as i live right on the border and sometimes only want to listen to them. How do i do this? Any help for the uninformed would sure be appreciated
N0WEF
Mpls, MN.
Considering, like DDan pointed out, you gave us no info to go on.... Let me just play the percentages.
I'm going to guess you have a 396 and FreeScan.
The easiest way to do something that small, and select, would be using EZGrab (It allows you to copy from a webpage and paste into FreeScan) Just create a system, set-up your CC, make a group, then copy from RR and click EZGrab, then "Copy from clipboard" check it so the rows are labeled correctly, and then click "Import into FreeScan"
