Need help finding something in Spectra RSS
Josh380
Orange County, CA
I know it's gotta be somewhere in there, but so tired of digging though the sea of screens.
I'm looking for the part that turns on/off the on hook PL (defeat, I think)..you know, how the radio goes open tone when the mic is off the hook. I need to turn it off.
Anyone know where that option is in the RSS?
rbrtklamp2
Dupage County, Illinois
I believe in the Astro25 CPS it is under radio wide settings. I'm sorry but I am not very familiar with spectras. But if there is some kind of radio wide menu I would start there. Sorry I can't be of more help with this one.
Sent from my SM-N910V using Tapatalk
Josh380
Orange County, CA
Thanks, but this is the older RSS I'm referring to, not the CPS. I've looked under radio wide and just can't seem to find it.
rbrtklamp2
Yeah I'm no good with old do RSS sorry. But I am sure somebody who is will come along and see this. I know it's as simple as just turning the feature off but I'm not sure where it's located in the RSS. Best of luck with it.
toolman60
Is this what you looking for.
Josh380
Orange County, CA
Maybe I should clarify, this is not an astro spectra, just spectra. I think we're getting closer though..haven't seen anything similar to that.
toolman60
Josh380,
Try this after you load code plug from main screen F4 then F2
Josh380
Orange County, CA
So HUB Switch is what I want to disable? I hate how they change what it's called...it's different in the maxtrac RSS.
W0JJK
I think HUB Switch is what you want to disable. I can look tomorrow and advise.
Josh380
Orange County, CA
Don't worry about it. Thank you. I'll give it a try and see if that does the trick. Makes sense because i've seen a wire marked HUB on a maxtrac mic..now I know what it is.
KG4INW
Midlothian, VA
HUB, as in the hang-up box of old. I've seen them refer to it as HUB or hook in different software packages but fortunately no other variation.
