Need help finding what frequencies to use for DOT
digiman5060
ESSEX COUNTY NJ
Need info what frequencies to use programming the NJ DOT both Garden State Parkway and Turnpike Authority for my Home Patrol Unit any help would be grateful
u2brent
OAMPT
KRWDPAXKRS1
If its the original Home Patrol, the ph2 systems are not compatible.
Motorola Type II SmartZone Omnilink
P25 Phase 2
Conventional
Department of Transportation (NJ DOT)
NJ DOT communications are on the 800 MHz State Police trunked system and on the newer 700 MHz NJPSIC under various talk groups. Some operations remain on these low band frequencies, namely NJ DOT snow plow trucks for truck to truck communications.
New Jersey Interoperability Communications System (NJICS)
Project 25 Phase II
DOT operates on this system
Frequency Input
License Type Tone Alpha Tag Description Mode Tag
47.26000 WQBK698 BMCSQNJDOT F1 NJ DOT F-1 Low Band FM Public Works
47.14000 WQBK698 BMCSQNJDOT F2 NJ DOT F-2 Low Band FM Public Works
47.36000 WPKH281 BMCSQNJDOT F3 NJ DOT F-3 Low Band FM Public Works
47.40000 WPKH281 BMCSQNJDOT F4 NJ DOT F-4 Low Band FM Public Works
mondaro
Harrison, New Jersey
Only Turnpike and Garden State Parkway maintenance use the system in TAC-1 response.
The NJDOT uses the NJICS system and can still be heard on the NJSP 800 mhz system.
I believe the low band channels listed about is no longer in use for the NJDOT however
older NJDOT trucks may still have those radios.
