Need help from you experts..
carolinascannerspy
Banned - Deadbeat Seller
First of all, i'm authorized to have the system key i'm referencing so please spare me the legal comments...With that stated, i need to load the system key into the CPS for an experimental XTS 3000 as my team wants to purchase some more of these radios if they like this one. Heres the problem: I do not have an ibutton so, how can i load the system key manually? Thanks!!
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
I presume you know how to navigate in Windows? To insert a file into a folder?
All you have to do is paste the system key file into the syskeys folder within the RSS folder.
Use Windows Explorer. (Not Internet Explorer! :D)
Elroy
carolinascannerspy
Thank you!
Thanks Elroy, i will try it tonight when i get to the station. I believe i tried it before but i'm not 100% sure i pasted it into the RSS folder.
carolinascannerspy
Gave it that 'ol american try but...
I tried to do what you stated but heres the problems i have now:
1>In what program can i save a .key file? I don;t see anything that allows me to do that.
2> It states (sometimes) it cannot load/save anything but IH?? system keys. This makes no sense to me or the system adminstrator who stopped by to check out the CPS software.
Thanks and i'll understand if it is too involved for you to provide any help. I do have access to a Moto shop here but they are expensive, slow and a bit snotty so thats why i'm back here. Many thanks!!
rescue161
KE4FHH
Hubert, NC
You just copy the "SYS0xxxx.KEY" file to a folder that you name what ever you like. Motorola typically defaults the system key folder to c:\Program Files\Common Files\Motorola\Syskeys. You don't need a program to copy it. The CPS will use the "key" to open up features in the CPS to allow you to program in that system.
Once it's copied, you open the CPS and then go to "Tools", then "System Keys", then "Load" and then "Normal System Keys". It will open a window and you search for where you look for the key that you copied.
RKG
Boston, MA
Actually, if you do it this way, the keys will be loaded for the current session only, and will not appear when the application is next booted.
To make the system keys available whenever the program is run, copy the key files to a location and then go to Tools|User Settings and define the path the key files.
carolinascannerspy
BIG thanks to both of you
Thanks guys, both of you. Greatly appreciate the tips. I got it. I had the path pointing to an empty syskey file i had vacated and named the same BUT forgot to delete. Live & learn i guess. Thanks again.
