Thanks for your replies.
> mel1718
> As far as I know the only scanner that will track provoice is the PSR-500 with the older fimware,
> I have the older pro92 and it will stop on TGs but will not stay there, it is not useable.
We have new Stock in these parts, my PSR-500 came with 1.7 and it is not downgradable (that far).
Thanks for the tip on the Pro-92. Maybe I will have to buy a
few off Ebay and park them on each Control.
> ... a pro 2050 ($35) and a pro 2052 ($50). ... a couple of older scanner and laptops do the trick ...
According to this Thread I'll need at least a 2052 for EDACS (does it do ESK also):
http://forums.radioreference.com/radio-shack-scanners/22687-pro-2050-a.html
or does it
not matter since I am using Unitrunker and DSD (and not relying on the Scanner's brain) ?
> Before you go through all the trouble make sure the system you are trying to get is not encrypted.
People out here are
Techno-Weenies, even the Bus Drivers use OpenSky (and live video) ! I'll have to listen to whatever I can. It sure would be cool to decode the Video and see onboard the Buses.
I bought the PSR-500 because I found DOCs for it's CPU and DSP so I expect that I will be able to hack the Firmware (with a year or two worth of work). Uniden seems to use proprietary components so that was a factor in my choice. I still have three weeks to return it but I would prefer not to.
> Unitrunker
> Don't scan. Park the radio on the control channel using either TSYS/Analyze or Tune.
Thanks. It was getting hundreds of Windows opening
I imagine you mean that _
I_ should "park" the Scanner on a Control Channel (and that "Park" in the
Menu should be set to an unused (no carrier ever) Channel - for the Program to
rest on).
I'm using your DOCs, various Tips in the Forums, stuff I Googled for and some guessin' -- may be a while before I figure it out.
(Understatement of the Decade
This Scanner is more complex that the one I had 20 years ago.
I'm just HAPPY Unitrunker does
something since that means I probably will not have to Tap it and as time passes more support will come for the PSR-500 in Unitrunker and other Programs (including actual homebrew Firmware).
Thanks you two, more answers (from others) for #6 welcome.
