W4UVV
I am using ARC536PRO and successfully did the DMR upgrade. I am using the 4 line scanner display and additionally am using the Virtual Control display on my WinXP OS computer. Everything seems to work as expected except a vehicle's radio unit number to display.
I deselected all other radio systems and am monitoring only the new FL for a high volume comm medical transport operation in Richmond, VA about 25 miles from me using MOTOTRBO Capacity Plus trs. The signal is fine and a new talkgroup displays only the number which is correct. After I id the talkgroup user which appears to be a total of four to present, I make the appropriate updates to ARC536PRO...no problem with talkgroups and updating my 536.
However, each medical van uses a computer tablet for either voice or data comms. I know I cannot receive data text comms. I hear both the dispatcher and van unit voice comms fine. But the van's radio unit does not display as a unit id on my 536 display or on the Virtual Control computer display.
Can anyone tell me what setting to change or how to correct the problem? There is a separate section in ARC536PRO for UIDs which require manual entries. I thought those were separate from radio unit's ids. Since I see no unit ids display either in a van initiated comm or dispatcher originated comm where only the talkgroup displays, what do I do to make mobile radio unit id display?
Any help will be appreciated.
John
John
