milcom_chaser
- Joined
- Jul 4, 2010
- Messages
- 979
The BNC antenna that came with this radio is so incredibly tight fitting, that I can not get it seat down and turn. I'm using another antenna as I did not want to risk damaging the BNC connector and or the radio itself. I called in to Uniden tech support, and went a around a few times explaining this issue. I requested Uniden simply send me another antenna to as a simple solution only to be thwarted repeatedly. I was told the techs need to evaluate the radio, I again said other antennas fit without risk of damaging the radio, which means the bnc jack on the radio is fine so this is an antenna problem. I don't want to tie up the radio for 4 weeks when it's clear the issue is with the antenna itself. Would be simpler just to send out a replacement antenna. I find this frustrating, and lacking perspective, a bigger picture with the customer in mind...
Thank You.
Thank You.
