W4UVV
I have a new PSR600. I successfully have programed area several 800 mhz. and the Va. STARS vhf trs system. They work fine. The city of Petersburg, Va., a few miles from my location has a "pure" 800 mhz. APCO25 trs. I can receive it fine on my Uniden 996T. Signal strength is not an issue as I have tower mounted antennas and am located 2-3 air miles from one of the simulcast sites. When I do a diagnostics analyze tune on the CC I receive a 99% confidence signal level, correct SID, NAC, confirmation it is a P25 trs, etc. and a solid "T" icon indicating a trunked system.
The Petersburg trs is the only trs in the selected VS folder. When I select the "scan" mode the "T" icon rarely displays as compared to the other trs I scan where it almost displays solidly. Only when the infrequent "T" icon displays and Petersburg transmits and both happen to time sync in a scan do I hear the transmission. When I do a manual selection of the default voice channel the signal is fine with good audio. All parameters were reset to factory defaults. I cannot find anything wrong with my other settings. Sight checking the object field shows the trs is being mapped. All talkgroups for Petersburg are in the appropriate talkgroup file. Multi site is set to "off" although I have tried all selections. I do not have a signal overload situation.
It appears that the 600 is not decoding all of the CC information in the "scan" mode. Does anyone have any idea why this one only "pure" APCO25 trs will not properly decode in the "scan" mode recognizing it as as a trunked system continuously or suggestions as to why or what else to try? A local acquaintance has a PSR 500 and it decodes Petersburg fine. He cannot find anything wrong with my settings on the 600. The 600 is supposed to have the latest CPU and firmware versions but I cannot locate the keyboard entries to check them.
I am using Butel ARC500 software for file editing and transfer. If no one can help me I guess I will have to contact tech support and possibly return the scanner. I cannot find a telephone number for them on the GREAmerica website.
