Got this cause it's compact & I'll use it for a 2 Meter rig and to listen to a statewide trunked system. For the statewide system, I've loaded all the voice channels & ACC's into one zone 1 & will load 2 meter repeater frequencies & some simplex frequencies into Zone 2. Have the same setup in my R30 & it works GREAT! Hears more sites than any of my 7 Unidens, including the SDS100. With this rig, I shouldn't have to worry about getting popped for violating VTL section 397, here in the less than wonderful state of NY.
I've loaded up 19 voice & ACC's in the 7010T, but cant get the rig to scan through them. I go to the Menu> Channel Scan> Scan Start/Stop >SCROLL TO "on" > OK, & get Scan Start / Stop failed. I programmed two of the side buttons for channel up channel down & they don't change the channels. The only way I can do that is to rotate the knob between the antenna & volume knob.
Any help would be greatly appreciated.
Thanks,
Bob / rja1
Thanks,
Bob / rja1
