need help programming motorola gp380
xcaliboy720x
I bout this radio online got programming cable and software. got everything to work ok. only one problem when i connect external mic im not receiving any audio but I am able to transmit does any one know the settings on how to turn it on or how to do it thanks anything will help thanks
Luis_R
Did you check all your connections? Do you receive with the external mic disconnected? Make sure all your contacts are clean, check for bent pins on the external mic connector, and that the radio and mic have a good connection. It's possible you might have a bad speaker or bad mic cord on your external mic. You could also have a problem with the flex, but most likely it's the external mic.
nukte
Same problem
Have 2 UHF gp380. Both have been programmed in exactly the same way. I can use the external mic. on one of them but not on the other. I can hear sounds from the external speaker but cannot transmit.
N1SQB
Somewhere On Earth
This seems to be a common problem with these radios. I have 2 UHF 380s and neither will accept an external mic without a problem either on TX or RX. I have had a Moto dealer check them out and they cant figure it out either. The GP-380s are supposed to be compatible with any accessory that their american counterparts (HT-1250s) use according to the info the dealer found. I just gave up and use them as is without the external mic.
Manny
